oasisniall Posted October 17, 2012 Posted October 17, 2012 Could anyone recommend what axle stands are best suited to use with a 350z? I didnt want to go buying a random set for them to be unsuitable when there may be a better set out there. Cheers Quote
spursmaddave Posted October 17, 2012 Posted October 17, 2012 I aquired 2 sets they don't look anything iut if the ordinary to me just standard ones.... it's the jack itself that is the issue especialky if your car is lower than standard Quote
Dblock Posted October 17, 2012 Posted October 17, 2012 I perfer the V shaped ones than the flat ones. Quote
samsniss350z Posted October 17, 2012 Posted October 17, 2012 The biggest problem i've had with axle stands is regarding the feet. I spent a few grand getting my drive tarmacked earlier this year replacing my paved driveway. The axle stands i used had feet that were just an extension of the angle steel used for the three legs, no footprint as such. I've had to get replacements with a proper pad/footprint after watching these thing sink into my smooth tarmac. The drive had been down for 3 months and it only happened a couple of weeks ago so it wasn't like the tarmac hadn't cured or was soft due to heat. I prefer a flat face unlike DBlock, as i mostly use my axle stands in the mounting point areas of the floorpan after using a trolley jack to get the car into the air. Quote
Dblock Posted October 18, 2012 Posted October 18, 2012 I don't have tarmac but the ones I have 4 feet so it spreads the weight but a pad would still be better on tarmac? Is it the halfords one you have? Quote
ioneabee Posted October 18, 2012 Posted October 18, 2012 just put a piece of 12mm plywood under the feet to spread the load Quote
rtbiscuit Posted October 18, 2012 Posted October 18, 2012 (edited) bit of ply like ioneabee say if its digging in. as for stands for the zed i have a set of draper ones one a ratchet lift, bought off ebay, works atreat everytime regardless of car. as its ratchet lift, there is alot more fine adjustment over the pin and hole method ones. also easier to lift up to fit, as it auto catches as you raise the foot. so if your one handed and trying to do it. theres no fiddly pin. Edited October 18, 2012 by rtbiscuit Quote
oasisniall Posted October 18, 2012 Author Posted October 18, 2012 (edited) Can anybody recommend any brands of axle stands because there is loads out there and some seem too cheap to be any good? Edited October 18, 2012 by oasisniall Quote
Dblock Posted October 18, 2012 Posted October 18, 2012 Draper, sealey and silverline, clarke are midrange but are good. Snap on/blue point if your a baller. Quote
Dblock Posted October 18, 2012 Posted October 18, 2012 baller axle stands i like it You should see the price of them lol. Also if your not lowered ramps can be handy for jobs where the wheel is left on oil service etc. Quote
RobPhoboS Posted January 2, 2013 Posted January 2, 2013 I'm after a set of the V-shaped ones, which I presume generally have a hard wearing rubber on them ? (I can use these on the sill points right ?) If so, can anyone recommend a specific set to go for ? The Silverline 580486 look ok but I'm not sure if anyone here has tried them. Quote
lmc Posted January 2, 2013 Posted January 2, 2013 Use these personally http://www.ebay.co.uk/itm/3-Ton-Axle-Stands-Ratcheting-Tall-High-Professional-Car-Van-AVR103-Arcan-New-/280960652886?pt=UK_Lifting_Moving_Equipment&hash=item416a8f5656 1 Quote
RobPhoboS Posted January 2, 2013 Posted January 2, 2013 Cheers for that, I guess those kind of ones are all the same just rebranded\painted differently. Do you use those ones on the sills without any issues ? Quote
lmc Posted January 2, 2013 Posted January 2, 2013 Cheers for that, I guess those kind of ones are all the same just rebranded\painted differently. Do you use those ones on the sills without any issues ? To be honest haven,t had cause to use them on the z yet but will do soon when my new anti roll bars turn up Quote
