Thanks all.
I was thinking that a da might be the way forward. What pad and cutting compound combination did you use Zugara and did you remove the headlights from the car or da them in situ?
Thanks all.
I haven't DA'd the Zed headlights but I have DA'd and used the roatary on others. I just leave them in situ, tape up the surounding area well and use a spot pad. I've only ever had to use a very light cut and a mild cut pad. You can always step up the combo if it's not doing the job. :)
I used megs scratch ultimate and did them on the car, used a soft pad on speed 4 on my da. just tape around the rubbers on the lights.
Thanks all.
