Replacement bleed nipple supplier?
I'm about to do a brake fluid change and thought I'd replace some of the brembo bleed nipples that have rusted over a little. Does anyone know of a supplier where I can get some stainless steel ones that fit the brembo? Does anyone know what size the brembo ones are?
I think they are M10x1.0 but what length?
Thanks,
Jim
Save yourself some cash.
If the standard ones are only a little tarnished, then use some very fine emry paper to take off the surface corrosion. then use a little Autosol to shine up. Sorted.
zmanalex would be able to supply original brembo ones I would think.
Yip! Plenty in stock, however as Lexx has suggested, a clean up is the way to go :thumbs:
  • 4 months later...
:bounce:
A very very kindly well respected forum member came round today for a look at my nipples :blush:
If nobody knows the exact sizes I guess I will have to go somewhere that can find out or take one out and measure it properly... They are apparently the exact size of the STI bleed nipples but I don't want to take a chance and cause any damage :surrender:
http://www.oakos.com/Merchant2/merchant.mvc?Screen=PROD&Store_Code=355&Product_Code=SB1010S&Category_Code=1065000
Didn't get time today mate but will have a look on Monday for you :):thumbs:
:bounce:
:bounce:
I wouldnt get them things IMO. I was going to get some too as I hate bleeding brakes but after reading reviews 70% of people say they are rubbish.
:bounce:
Do we still have these? Did he have a clipboard? ;)
I've had a little look online and it appears that the majority of brembos are an m10 thread, I'll pop one of mine out & measure it if you want? But perhaps give Hi spec ms a ring first
:bounce:
Cheers Darren, yeah all the links I have seen say m10 but I need to know the exact length too :wacko:
WIll give Hi Spec a call Monday and try and get down there Tuesday if poss, thanks for all the help, just well it was flipping freezing yesterday :cold: at least it made finding the nipples easy ;)
