Zugara Posted August 10, 2010 Posted August 10, 2010 I had a slight overflow today of brake fluid.....don’t ask! Any way is it true or fiction that brake fluid has a detrimental effect on painted surfaces? Or was that on the 2 Pac paint? Washed all of the fluid away with plenty of water, so i should be ok if the fluid doesn't ruin paint work. So far it looks ok... Quote
Ekona Posted August 10, 2010 Posted August 10, 2010 You really don't want to be getting brake fluid on ANYTHING. Paint and skin are possibly the worst two. As long as you were quick you'll probably be fine. Quote
andlid Posted August 10, 2010 Posted August 10, 2010 You really don't want to be getting brake fluid on ANYTHING. Paint and skin are possibly the worst two. As long as you were quick you'll probably be fine. it's a pain to get on your skin, should start to use gloves really... The water rince should be fine,. Quote
Troll Posted August 24, 2010 Posted August 24, 2010 Yes it is true I have seen brake flue strip chassis paint, garage floor paint and put holes in my jeans. Evil stuff! Quote
Husky Posted August 24, 2010 Posted August 24, 2010 it's a pain to get on your skin. i imagine it being quite easy to get on your skin Quote
andlid Posted August 24, 2010 Posted August 24, 2010 it's a pain to get on your skin. i imagine it being quite easy to get on your skin Quote
cooin Posted September 2, 2010 Posted September 2, 2010 it's a pain to get on your skin. i imagine it being quite easy to get on your skin sad.... Quote
Wasso Posted September 2, 2010 Posted September 2, 2010 I had my car vandalised years ago with brake fluid.... eats everything in sight!! If it eats through the paint it will soak into the bodywork.... this equals write off!! As you won't be able to paint over the vehicle again! It also eats into plastic rather nice!! Quote
Husky Posted September 2, 2010 Posted September 2, 2010 it's a pain to get on your skin. i imagine it being quite easy to get on your skin sad.... true, was having an off day clearly Quote
bigbramble Posted September 2, 2010 Posted September 2, 2010 If you wiped it straight off you will be fine, lots of experience tells me that Quote
