cdbritten Posted June 25, 2010 Posted June 25, 2010 I've got an 08 350z Gt pack. The clutch pedal stays on the floor if I drive it hard form a stationary position. Took it to a dealer who confirmed the fault. They replaced the entire clutch and slave cylinder. They stripped and rebuilt the gearbox and replaced various synchros - all under warranty. They told me to bed in the clutch for 100 miles - I did. It was still the same. Nissan UK said it needed to be bedded in for 500 miles - done that and it's still the same. ESP makes no difference. It's now back there waiting for the next pearl of wisdom! Anyone got any further than this? Quote
Ekona Posted June 25, 2010 Posted June 25, 2010 Define 'drive it hard from stationary'? Did they replace the master cylinder as well? How about the clutch line? Why did they rebuild the gearbox? Quote
3FIDDYZ Posted June 25, 2010 Posted June 25, 2010 Would drive it hard from stationary mean "launching it off the line" ? Quote
ZMANALEX Posted June 25, 2010 Posted June 25, 2010 Providing the concentric slave is not sticking on the 1st motion shaft housing then all that is left that may cause this fault is the master cyl. providing they have got all the air out the syatem. Quote
cdbritten Posted June 26, 2010 Author Posted June 26, 2010 Would drive it hard from stationary mean "launching it off the line" ? That would be a good definition! They said there was a synchro fault on 4th. The clutch works perfectly the rest of the time. If I slip it from rest the pedal stays about an inch or two off the floor and I need to lift it up manually. The pedal then feels 'soft' for a while. The smell of burning clutch is also very prevalent. As I said Nissan have confirmed the fault and agreed it's a warranty issue - more than some others have got out of them as far as I can tell. Interesting to test out their warranty if they can't - as I now suspect - sort out the fault. I've read elsewhere that an after market clutch is one solution - possibly the only one. Quote
Ekona Posted June 26, 2010 Posted June 26, 2010 Change the master cylinder. I've had the same fault recently, and changing the slave did nothing to improve it. However, changing the master solved it perfectly. Also the clutch isn't going to last very long if you rag it like that, so either don't do it or get an uprated clutch. You've more than likely knackered the one already in there by now so it probably needs changing anyway. Quote
cdbritten Posted August 12, 2010 Author Posted August 12, 2010 Change the master cylinder. I've had the same fault recently, and changing the slave did nothing to improve it. However, changing the master solved it perfectly. Also the clutch isn't going to last very long if you rag it like that, so either don't do it or get an uprated clutch. You've more than likely knackered the one already in there by now so it probably needs changing anyway. Nissan dealer removed the clutch which was 'burnt out'. They put it back together and said that was it - have it back. After weeks on the phone to Nissan Uk they finally agreed to put another new clutch in under warranty. In other words do the same as last time. So I've given up. I've part exed it for a Cayman S. I think that if Nissan are going to build a sports car they should do it properly. You ought to be able to drive it hard. On another note my neighbor has just given his GTR back because he got fed up with faults on it. He's got an Aston. hey ho. All the best to you guys and thanks for the support. Quote
sparky370z Posted August 12, 2010 Posted August 12, 2010 Change the master cylinder. I've had the same fault recently, and changing the slave did nothing to improve it. However, changing the master solved it perfectly. Also the clutch isn't going to last very long if you rag it like that, so either don't do it or get an uprated clutch. You've more than likely knackered the one already in there by now so it probably needs changing anyway. Nissan dealer removed the clutch which was 'burnt out'. They put it back together and said that was it - have it back. After weeks on the phone to Nissan Uk they finally agreed to put another new clutch in under warranty. In other words do the same as last time. So I've given up. I've part exed it for a Cayman S. I think that if Nissan are going to build a sports car they should do it properly. You ought to be able to drive it hard. On another note my neighbor has just given his GTR back because he got fed up with faults on it. He's got an Aston. hey ho. All the best to you guys and thanks for the support. he went from a GTR to a Aston and thinks he wont have any problems with it? oh dear!! some people i have spoken to about their Aston's have said never again. spent most of their life in the garage for some faults or others! lol. but hey i would love to have the choice! Quote
dyla350z Posted August 12, 2010 Posted August 12, 2010 mine has done it once in 1st when i hit the rev limiter,not done it since but it was suggested it was the master,unless it becomes a prob i wil leave untill i need a clutch,ive set my rev red light to 6600 so i dont hit the limiter just in case. Quote
cdbritten Posted August 14, 2010 Author Posted August 14, 2010 mine has done it once in 1st when i hit the rev limiter,not done it since but it was suggested it was the master,unless it becomes a prob i wil leave untill i need a clutch,ive set my rev red light to 6600 so i dont hit the limiter just in case. I only did it three times on a new clutch and the clutch was cooked. Not good enough - this is their top of the range sports car and you should be able to drive it like a sports car not a micra. If you're in warranty take it back. I'll give you the reg of mine as evidence if they play =hard to get. I have read that a heavier racing clutch will sort out the problem. Quote
