RichIX Posted April 15, 2010 Share Posted April 15, 2010 Hi Guys, My Z's Air Con is really rubbish at the moment do you have any recommendations on where to get it done at? Im in Leeds... (wishful thinking of a hot sunny summer!) Also, my CD player (standard OEM one that came with the car) seems to skip (Alot!) when the car is cold? is this normal? when the car is warm the cd's play fine.... Thanks for your Help! Quote Link to comment Share on other sites More sharing options...
Ekona Posted April 15, 2010 Share Posted April 15, 2010 Anywhere can do an A/C regassing, I'd probably take it to Nissan and get them to do it rather than a generic Kwik Fit place mind. Quote Link to comment Share on other sites More sharing options...
mattbowey Posted April 15, 2010 Share Posted April 15, 2010 re cd player, just make sure the car warms up nice and quickly Quote Link to comment Share on other sites More sharing options...
M13KYF Posted April 15, 2010 Share Posted April 15, 2010 or you can send your Bose to R35LEE and he can fix it. PM him Quote Link to comment Share on other sites More sharing options...
toffeeblock Posted April 15, 2010 Share Posted April 15, 2010 For the CD player, if you are within the 3 year warranty period Nissan will replace this for free. Mine got replaced this way. After 3 years, despite it being reasonable for you to expect a CD player to last longer without failure, you'd be lucky to get Nissan dealers to cover this I reckon! Quote Link to comment Share on other sites More sharing options...
Tarmac@TarmacSportz Posted April 15, 2010 Share Posted April 15, 2010 I got my Aircon re-gassed at a garage in Derby for around £50... Not a big job so if someone tries ripping you off tell them to do one !!! Quote Link to comment Share on other sites More sharing options...
northernuk Posted April 15, 2010 Share Posted April 15, 2010 I can't comment on having the Z re-gassed but I have had my last one done 3 times at different places. It is pretty straight forward and had no issues with any of them. It appears to be something that can be done by anyone with a modicum of techincal knowledge so no need to pay top dollar IMO.... Re the CD skipping... This happened alot with my 6CD Changer in my other car as well. I guessed it was down to condensation on the CD's as it warmed up or something. I would get different results if I brought a CD from the house or used one that had been in the car all night. Maybe it is different for Z's if there is a fix as mentioned though... HTH a little. Quote Link to comment Share on other sites More sharing options...
Stretch Posted April 15, 2010 Share Posted April 15, 2010 If it's the six CD Bose unit its a common fault mate, mines exactly the same but after about ten mins to warm up it plays absolutely fine Quote Link to comment Share on other sites More sharing options...
nixy Posted April 15, 2010 Share Posted April 15, 2010 and remember once the aircon has been done, you need to run it regularly to keep it going properly. Quote Link to comment Share on other sites More sharing options...
RichIX Posted April 15, 2010 Author Share Posted April 15, 2010 Thanks for all the replies guys, your stars.. The car is still under warranty for another year I think so I might get it sorted via them, bit annoying that a 2 year old Z has this problem, yet like you guys say after its warmed up no problem at all with the CDs (it is the 6 CD Changing unit I have)... I have taken the CD's out on a morning and there is no condensation or "misting" on them so was a bit miffed... Might as well get it re-gassed at the stealers whilst its there as long as its not more than £50.. Quote Link to comment Share on other sites More sharing options...
Dblock Posted April 15, 2010 Share Posted April 15, 2010 are you sure it needs regassed. A guy on another forum was an ac engineer and said really they only needed to be regassed if there was a leak. if you use the ac often then it will work better even if it isnt too great now. Quote Link to comment Share on other sites More sharing options...
helimeddaz Posted April 15, 2010 Share Posted April 15, 2010 Hi Guys, My Z's Air Con is really rubbish at the moment do you have any recommendations on where to get it done at? Im in Leeds... (wishful thinking of a hot sunny summer!) Also, my CD player (standard OEM one that came with the car) seems to skip (Alot!) when the car is cold? is this normal? when the car is warm the cd's play fine.... Thanks for your Help! Hi, I'm just down the road in Sunny Cas. Had my old 200SX re-gassed by a local firm some time back. Don't remember the name of the lads company, but He's call Adam Tel:- 07973 665249. from Kippax. Top job, knew his stuff when he did it. Quote Link to comment Share on other sites More sharing options...
AlexZ Posted April 15, 2010 Share Posted April 15, 2010 Hi mate, as Dblock mentioned the only reason you should need it regassing is if theres a leak. We have the machine at work..You just plug the macine pipes to the feron tubes on the car, put in the weight of gas and leave it to it. Yours might not have the full gas amount in from factory... I would try using it a little more, or compare it to another 350z if you know anyone...The air con system is pressure sealed so it should really be coolio. Alex Quote Link to comment Share on other sites More sharing options...
RichIX Posted April 16, 2010 Author Share Posted April 16, 2010 Just rang stealers and my car is still under warranty till August so going to get it booked in there next week and get it sorted, do you know if they replace the whole headunit or just repair it? Quote Link to comment Share on other sites More sharing options...
toffeeblock Posted April 16, 2010 Share Posted April 16, 2010 For my head unit then initially just took note of the serial number or something, ordered a replacement (refurbished probably) and swapped them over a few weeks later - I was never without sounds! (Take a good luck at your Rays alloys before you go in, any signs of bubbling etc., and have them replaced with refurbished ones too while you are at it. Another common problem to look over under warranty, they took snaps and got Nissan UK to authorise the work, also took a few weeks to sort out but no problem.) Quote Link to comment Share on other sites More sharing options...
s1xtyn1n3 Posted April 16, 2010 Share Posted April 16, 2010 most places will put a uv pigment into their ac gas to check for leaks. certainly have at least for the last 2 cars i've owned at various different garages. Quote Link to comment Share on other sites More sharing options...
RichIX Posted April 16, 2010 Author Share Posted April 16, 2010 Will find out on Monday as its going in then, they must be quite... There is some large bubbling on the alloys so will get them to look at that as well.. Quote Link to comment Share on other sites More sharing options...
