plenum question
drob
i mean the gasket under the lower plenum, didnt see why i had to take it off in the first place
:wacko: you didnt need to take the lower plenum off for a plenum install. you will need to reuse the oem gasket and also use the provided gasket that came with the spacer. B)
I'd use a bit of gasket on tube and locktite on the bolts too, and not overtighten the 6 middle ones! B)
yeah thats the one, never did it today anyway it snowed :thumbdown: ill just do it i think its not exactly open heart surgery to put it on
If you have done the pleunum its just another 6 bolts to undo. IMO worthwhile if you undone the other 20 odd!
agreed, case closed. :thumbs:
