yeti Posted December 1, 2009 Posted December 1, 2009 Can anyone explain why my battery was flat this morning? 56 plate Z, 35k used every day on a 120miles total commute. Got up in the ice this morning expecting to go outside and start the z up to warm her and the heated seats up and the battery was flat as a pancake. The was nothing on when i came to the car (lights/indicators/heated seats etc all off) Has anyone had their battery drain in 12hours before? It wasnt locked, would that make a difference? cheers andy MODS: couldnt see the appropriate subforum so i put it in here Quote
Chris`I Posted December 1, 2009 Posted December 1, 2009 I had something similar on my 53 car, it was because the battery was shot. New battery and everything worked like new. 56 plate seems a bit "young" for the battery to be gone but it could be. Moved to Technical for you Quote
Trev-the-Rev Posted December 1, 2009 Posted December 1, 2009 Yeah I agree with Chris. If you are sure nothing was left on then get the battery checked. Quote
R35LEE Posted December 1, 2009 Posted December 1, 2009 Get the battery checked Andy, sounds like it's kaput Quote
yeti Posted December 1, 2009 Author Posted December 1, 2009 Yeah chers fellas i'm gonna try and steal a multimeter at some point today and get out there and have a look but for now i have the efficient 'spare battery' jump techique! - luckily i have a few batteries from by Corrado on the garage on trickle charge and they are man enough to start the z. O if any ones thinking they'll be ok if they get a flat battery cos they have a big diesel car like me thaen be careful, The Battery Nissan puts in their new Xtrails isnt big enough and neither is the battery in a diesel passat but i suppose theire only 4 cylinders so that might explain it Mine still under Nissan delaer warranty, any idea if battery's are covered? Quote
M13KYF Posted December 1, 2009 Posted December 1, 2009 Mine still under Nissan delaer warranty, any idea if battery's are covered? I doubt it, normally comes under perishables Quote
givememorepower Posted December 1, 2009 Posted December 1, 2009 With the engine running and a multi-meter across your battery terminals you should be getting a steady voltage as close to 12v DC as poss. Check if maybe your battery is dry, and possibly the tension of your alternator belt. Quote
Chris`I Posted December 1, 2009 Posted December 1, 2009 Mine still under Nissan delaer warranty, any idea if battery's are covered? I doubt it, normally comes under perishables Yup, unless it dies in say less than a year, they'd tell you to feck off! Doesnt the alternator put out more than 12v? I thought it was nearer 14v Quote
Andy Posted December 1, 2009 Posted December 1, 2009 +1 was going to say, while you have the meter out, it's worth checking the alternator as well. Quote
stanski Posted December 1, 2009 Posted December 1, 2009 Dont forget you already have a Voltmeter in the car! Quote
Stew Posted December 1, 2009 Posted December 1, 2009 14.4V approx is the alternator charging voltage. Quote
yeti Posted December 9, 2009 Author Posted December 9, 2009 ok so its still doing it, driven 600+ miles since i noticed it. The battery is still draining when left alone for more than 12ish hours to just enough to not start the car (just under 12v on the guage), but as soon as its started you can drive anywhere and providing its a little while to recharge the battery it's fine to sit for hours and then restart (ordinarily sitting around 15v when driving and sitting after along run). Fortunately i tend to get back from work late and i start early so it doesnt have time to drain enough ordinarily... i'm carrying a spare battery and jump leads in the boot just in case though The battery seems ok, the alternator is working fine as its re-charging but the airbag warning light is still flashing at me. I havent yet had the time to remove the drivers seat i removed to trial fit new seats a while ago, as i want to check the wiring underneath. Hoepfully i'll have time this weekend to check it all out properly Quote
