LRF4N Posted August 10, 2009 Posted August 10, 2009 a week or so ago my cars been playin up, its stopped switching automatically to non recycled air when i turn the AC on or when i turn the fans to the windscreen, anyone heard of this problem before? not a major issue but would like to get it sorted Quote
mic-39 Posted August 10, 2009 Posted August 10, 2009 I have noticed that if the temperature is set pretty low the car automatically turns on recycled air and you have to switch it over to fresh air automatically. My Nissan jeep also has this annoying feature Quote
Lincolnbaggie Posted August 11, 2009 Posted August 11, 2009 You can set the recirculation up to either manually provide fresh air (press the middle button until the left hand light is on) or recirculate air (press the middle button until the right hand light is on), or it can be set up to automatically adjust itself (press the middle button for a couple of seconds and then both lights flash twice and it enters automatic mode). Check page 3-3 in your manual. Maybe you've inadvertently set it to either manual or automatic without meaning to? Quote
Toon Chris Posted August 11, 2009 Posted August 11, 2009 You can set the recirculation up to either manually provide fresh air (press the middle button until the left hand light is on) or recirculate air (press the middle button until the right hand light is on), or it can be set up to automatically adjust itself (press the middle button for a couple of seconds and then both lights flash twice and it enters automatic mode). Check page 3-3 in your manual. Maybe you've inadvertently set it to either manual or automatic without meaning to? Good answer! All the little twiddles I didn't know my car had, and I read the manual but not daily and you just forget these things Quote
LRF4N Posted August 11, 2009 Author Posted August 11, 2009 You can set the recirculation up to either manually provide fresh air (press the middle button until the left hand light is on) or recirculate air (press the middle button until the right hand light is on), or it can be set up to automatically adjust itself (press the middle button for a couple of seconds and then both lights flash twice and it enters automatic mode). Check page 3-3 in your manual. Maybe you've inadvertently set it to either manual or automatic without meaning to? ahhh ok il give that ok thanx Quote
