2004 350Z W Brace and Rear Member Stay replacements advice, prices + any discount appreciated plus Leadtimes
Hi there,
I have a Nissan 350Z 2004 plate and I am looking at changing the W Brace as it is corroded and needs replacing.
While under the car I thought I would change the rear member stays RH/LH also as they are heavily corroded and would make sense to do at the same time.
I assume if I buy this:
https://www.torqen.uk/nissan/350z/suspension-steering/braces/20421-350z-nissan-oem-rear-suspension-member-stay-bracket-with-hardware-kit-right-55451-cd001.html
https://www.torqen.uk/nissan/350z/suspension-steering/braces/20422-350z-nissan-oem-rear-suspension-member-stay-bracket-with-hardware-kit-left-55452-cd001.html
https://www.torqen.uk/nissan/350z/suspension-steering/braces/20746-350z-ultra-racing-rear-lower-brace-4-points-rl4-1259.html
https://www.torqen.uk/nissan/350z/suspension-steering/braces/5596-350z-nissan-oem-w-brace-hardware-kit-74870-cd200-hwk.html
I will be covered for all parts and replacement bolts? Or do I need another 4 of these for each side re the Stay Braces? As I note I need to remove 2 bolts (supplied) and 3 nuts but only 1 is supplied?
Also would I be able to get any discount please for being a member of the 350Z foum and what would be the leadtime on the parts to mainland UK deliver?
Many thanks in advance
Larsdowg aka Rick
Hi Rick,
Many thanks for your enquiry!
This is everything you need to replace the member stays, the w brace and the hardware for each.
We have all of these in stock so they can be despatched for next day delivery, unfortunately we can't do discounts on OEM products as we price them competitively to even what Nissan would.
If you have anymore questions, feel free to let me know or pm me at anytime.
Edited by Coz@TORQEN
  • 2 months later...
Hi Coz, thread jump... are the Ultra racing designed to replace the OEM brace or (as was called out in separate threads) designed to be used as-well-as/in addition to OEM?
Hi there Zalas,
It replaces the original OEM W Brace. Really good bit of kit, in my opinion better than OEM.
I took the OEM one off, put my foot on it and folded it in half and my 2004 ZED has only done 27k miles.
Highly recommend, plus change the member stays as they were rotten too.
I recommend buying both bolt packs too as the old bolts required a lot of penetration oil and a couple a blowtorch to persuade out.
Hope this helps.
Stay safe.
