separating gearbox from engine
plebpl
Hi guys, im half way through changing my clutch, all the bolts etc are out from the bell housing. But the gearbox wont come away from the engine. I can get a few mil all the way around so I know its not a bolt, but it just wont come off. Is there some trick to this that im missing? or is it just a case of keep wiggling it until it comes free?
Bottom of the gear box small dust cover held in with a 10mm bolt IIRC removed from engine side and its above the cross bar - did you get that? If so then as Alex said pry bar is the way ahead - even better 2 - one on each side so it come off square :thumbs:
Hi guys, thanks for the comments, I tried prying it apart for hours before I made the post, it was well and truly seized on there. In the end, I got a ratchet strap around the rear sub frame, and ratcheted the hell out of it. It eventual released with an almighty bang lol.
