Stillen gen 3 engine light ?
Kharmon
Hi guys just installed the stillen gen 3 intake. booked it for a tune on the 21st .The only problem is my check engine light is on any idea why ? The car seems to be driving fine . Could the maf sensors need cleaning ? If so what do i clean them with ? Thanks in advance
And now you have no idea what the code was, could've been something important. Why did you not just get it read?!
I have to agree with Dan you would have been much better checking the code Op just to be certain as to why it came on.
I mean if you knew for example it was caused by a secondary O2 sensor fault after fitting HFC's or De-Cats then by all means reset the ECU and wipe the code but without knowing is a little haphazard.
Hopefully it was nothing serious. Definitely worth following sipar69's suggestion imo. :thumbs:
I read on the american forum that it happens if you dont disconnect the battery during the install which i never .so dont worry the ecu just needed resetting. Will have a look in to getting one of them wifi dongles though sounds handy to have thanksðŸ‘
