Knocking sound from gear box
mitman2501
Hi all newbe so have a few Qs
So when on idle I can hear a loud knock that last seems to be coming from the low end of the gear box.
This doesn't happen when cold only after a drive.
Gears are fine in fact feels lovely also not long had a new clutch fitted!
Any ideas!
Newbe Qs
Only on tickover the car is stationary I can hear a knock sound coming from gearbox now and again only happens when warm and the cars in neutral.
I can hear it more with the bonett open, but can feel the knock if I hold the shifter drives fine not long had a new clutch fitted by last owner.
Any one?
Edited by mitman2501
Once you've had a drive let it idle then put the a/c on. If it stops doing it it may be a normal feature of the car. Mine on normal idle used to do this when warm as the revs fluctuated slightly and the knock could be heard around the gearbox area. Putting the a/c on means it ticks over at slightly higher rpm and the intermittent knock ceased. I've just had all my bearings and clutch replaced and it no longer does it.
