Robz350z Posted June 15, 2016 Posted June 15, 2016 Replaced my hatch struts, but in my over-eagerness/stupidity managed to shear off a nut in the C-pillar! How the hell do I get this out? Gutted.com Quote
GreenLandy Posted June 15, 2016 Posted June 15, 2016 Is there enough sticking out to get a stud extractor onto it? If it's flush, then drill out and re-tap 1 Quote
Robz350z Posted June 15, 2016 Author Posted June 15, 2016 Nope, it's flush. I'll have drill and tap it at the weekend then, bugger. Quote
H1979 Posted June 15, 2016 Posted June 15, 2016 Is there no way you can dremel a slot in the nut and use a Flathead screwdriver? Quote
GreenLandy Posted June 15, 2016 Posted June 15, 2016 I imagine he meant the bolt that holds the strut to the c pillar, not nut. I guess you could attempt (with a lot of surrounding damage probably) the dremel method on what's left of the bolt, but if it sheared it must be in megatight/rusted in and will probably just chew up the slot Quote
Rob332 Posted June 15, 2016 Posted June 15, 2016 (edited) If it's flush, drill a hole down the centre then wind in a stud extractor. It might come out without you having to drill it out completely and re tap. Sometimes the simplest of jobs turn out to be the worst. Edited June 15, 2016 by Rob332 1 Quote
Keyser Posted June 15, 2016 Posted June 15, 2016 weld a new nut on the top - gives you something to grip and the heat releases the threads 1 Quote
Robz350z Posted June 15, 2016 Author Posted June 15, 2016 I'll try what Rob suggested first, Dremmel is a non-starter, far too flush. Welding is a possibility too. Cheers for the help guys! Quote
veilside z Posted June 16, 2016 Posted June 16, 2016 Which ever way you decide... Good luck buddy 1 Quote
Robz350z Posted June 16, 2016 Author Posted June 16, 2016 Cheers bud, so pi**ed off with myself though. Quote
Robz350z Posted June 18, 2016 Author Posted June 18, 2016 Cracked on with this today. Used stud extractors first, which worked at first, but winding it in the top snapped off! Had to file the top of them down and got them out. Got the rest out with tapping and drilling, swearing, new strut on now *phew* Quote
Mack Posted June 18, 2016 Posted June 18, 2016 Good to hear you got sorted. Im not a fan of stud extractors aka easy outs. They are extremely brittle and unbelievably hard. I learnt the hard way, took me nearly a day to drill out the remains of one. 1 Quote
