New LED rear indicator, reverse and side lights
E bay Carlab-design-tuning £114.95.
Bit of wiring bumper has to come off. 3-4 hours work
Mine were from Carlab there's a thread on here all about them and a discount. Very easy to fit , bumper off then pretty much plug and play ( you will need to do a small very easy mod to have the fog light working).
Been thinking about these for a while, any ideas on where I can find the mod?
Has anyone suffered with water ingress into theres? Mine are fitted and seem to be collecting water 😬
It's one I did, literally just adding a pin and foglight wire to the empty port on the carlab plug. I can help you with it if your near to me.
I've not but then I've only been out in the dry since fitting. I know Hodaka had a water ingress problem with one of his.
Did he? I use mine as a daily so its been through alot but the water doesn't seem to be getting worse.
Im wondering if its condensation from the exhaust?
I did put some silicone sealant around the plastic welds as a precaution but its obviously not worked :(
Ive e-mailed them anyway.
  • 4 weeks later...
