Wheel spacer wobble - help
checkers88
So I've just received my 30mm front and rear wheel spacers in the post and after spending much time fitting them I've noticed that I get wobble through my steering above 30mph. They don't rub or catch, i wire brushed the hub and copper greased the bolts etc. They seemed to fit snuggle enough even though they aren't hub centric ones but I can't think why they are wobbling. I didn't have a torque wrench so they were hand tightened so possibly this could be a culprit?
Any ideas?
P.S sorry if this has been covered.
Pics of the spacers would be a good to understand your set up. IMHO, I think 30mm front and rear might not be ideal and it's putting more stress on your wheel bearings. Try removing them and test drive to see if this will still happen?
Don't know if it's just me, but those studs look too short for the spacer.
Yes, that's the way it looks to me too. The wheel nuts should have an absolute minimum of 7 or 8 complete turns on the stud and 10 is recommended.
Pete
