Trickle Chargers through the Ciggy Lighter
ioneabee
The car is often left 3 or 4 days without being used and my car cam is permanently wired with a voltage checker on it (turns it off if the volts in the battery drop too much).
To maintain the charge in the battery and keep my camera running - has anyone used the above ?
recommend a product ?
things to do / not to do ?
Also noted that the ciggy lighter must be permanent live (I haven't checked this yet)
I use the Carcoon battery conditioner made to manage the battery and run the carcoon if neccessary. You have a permanent connection onto the battery and a connector for easy connecting/disconnecting.
Mine sits over winter with no issues.
bugger - no power to the ciggy lighter when all switched off...........thats the easy solution unavailable
the CTEK has a permanent connection available, which means having the bonnet popped every time I want to connect/disconnect
  • 1 month later...
Just a thought...
a ciggy lighter trickle charger......
which takes power from the ciggy lighter....
which is connected to the battery......
that you are trying to charge.....
except .............. they go from a mains charger into the ciggy lighter to trickle charge the battery :p
