When i open my drivers do the window auto drops, but when i close it the window stays down. Is there any reason as to why or is it a fault with the window motor.
Also should the passenger window auto drop or just the drivers side.
both drivers and passengers sides should drop when the door is opened. if its dropping but not coming back up, try testing the door closure sensor, might be a faulty switch sensor rather than a dodgy motor.
These window mechanisms are a nightmare 😔
I'm hopefully stripping mine down next week but it's weather dependent.
Will let you know how I get on.
  • 1 month later...
My passenger one also doesn't auto drop. I also need to try the reset but as it's a roadster I'm worried I'm going to bugger up the roof too!
My passenger window is intermittent - sometimes works, sometimes nit - it on the to do list but not a priority
My passenger window has never dropped on opening in the 5 odd years I've had the zed, never caused a problem and works fine on the button up/down.
If you have disconnected your battery recently you will no doubt have had this happen to you. Its a safety feature to prevent smashing the glass against the frame in the case of battery failure. The window will drop down on opening but it wont go back up on closing. If you repeatedly open and close the door the window will get lower and lower. If this is happening to you then all you need is a window reset as mentioned above.
If the window is not dropping at all when you open the door this likely means its another issue entirely and not linked to the safety feature mentioned. I would first try disconnecting the battery for a few minutes, then reconnect and immediately perform the window reset procedure. This may get you back up and running but if not its likely a motor or sensor playing up.
  • 4 weeks later...
When I bought mine the passenger window didn't drop on opening the door. I stripped the door down in about 5 minutes using a tutorial I found online, and then followed Nissan's official reset procedure (also online). It's working flawlessly now, although I must add that it never actually caused any trouble when it wasn't working. I only wanted to fix it because I don't like when things don't work as they intended (which is probably why I always end up spending so much fixing the silliest little things on my car :D)
edit: edited for smiley.
Edited by Puffmac
