KUGT4 Posted July 2, 2015 Share Posted July 2, 2015 clutch pedal would only return half way (now returned to normal) - anybody else have this problem during the heatwave? Â guessing (from internet searching) that it's the clutch fluid 'boiling' due to slave cylinder flexie hose proximity to exhaust and/or the flexie hose deforming under the heat Quote Link to comment Share on other sites More sharing options...
glrnet Posted July 2, 2015 Share Posted July 2, 2015 ^ That Quote Link to comment Share on other sites More sharing options...
KUGT4 Posted July 2, 2015 Author Share Posted July 2, 2015 cheers - is the fix as simple as just replacing oem clutch fluid for high spec stuff? Quote Link to comment Share on other sites More sharing options...
Ewen@Clark Motorsport Posted July 2, 2015 Share Posted July 2, 2015 Try changing the fluid first as it may be old, if that does not work it may be the slave cylinder on its way out. We can supply a slave cylinder upgrade kit if required Quote Link to comment Share on other sites More sharing options...
milseyman Posted July 3, 2015 Share Posted July 3, 2015 mine done same thing today Quote Link to comment Share on other sites More sharing options...
KUGT4 Posted July 4, 2015 Author Share Posted July 4, 2015 (edited) cheers guys - any non-OEM clutch fluid preference or do nissan do a high temp version? Edited July 4, 2015 by KUGT4 Quote Link to comment Share on other sites More sharing options...
Vlad Posted July 4, 2015 Share Posted July 4, 2015 Stick motul 600 or 660 in it Quote Link to comment Share on other sites More sharing options...
chips Posted July 4, 2015 Share Posted July 4, 2015 question: If this happened and it wasn't considered to be in 'heatwave' conditions, ie: in Australia where this is a regular temperature wouldn't this be considered a manufacturing defect/shortfall or is the build a different spec? I know the rules allow a car to go from UK to AU and will pass standard roadworthy checks so I thought the builds were the same? If not then is it that the lower temperature climate allow a longer life of components in this case and Ewan's advice is right. If it's same spec builds then that advice would be right. Or, the only other exception I can think of, were you participating in a donut competition at the time? Quote Link to comment Share on other sites More sharing options...
Vlad Posted July 4, 2015 Share Posted July 4, 2015 I'm sure it would be ok... As I guess it only happens when fluid doesn't get changed for a very long time or something like slave cylinder fails...I guess it just classed as wear. Doesn't happen to every one, so there are different factors that will cause this Quote Link to comment Share on other sites More sharing options...
KUGT4 Posted July 4, 2015 Author Share Posted July 4, 2015 question: If this happened and it wasn't considered to be in 'heatwave' conditions, ie: in Australia where this is a regular temperature wouldn't this be considered a manufacturing defect/shortfall or is the build a different spec? I know the rules allow a car to go from UK to AU and will pass standard roadworthy checks so I thought the builds were the same? If not then is it that the lower temperature climate allow a longer life of components in this case and Ewan's advice is right. If it's same spec builds then that advice would be right. Or, the only other exception I can think of, were you participating in a donut competition at the time?  saw a number of australian posts during my searching  350z 'feature' IMO Quote Link to comment Share on other sites More sharing options...
Ewen@Clark Motorsport Posted July 4, 2015 Share Posted July 4, 2015 As its runs close to the exhaust this is what seems to affect it over time but as Vlad says old fluid is normally what causes this initial problems Quote Link to comment Share on other sites More sharing options...
