mr_smith126
The big FLUIDS list - **ADD YOUR SUGGESTIONS**
Had a few questions about bits as preparing a shopping basket for service items.. seemed to find the info all over the shop, so have started this list...
Let me know of amends/additions and suggestions and i'll update the list.
The format i've followed is:
ITEM NAME
ITEM INFO/SPEC/GUIDANCE (*UK SPEC*)
SUGGESTED BRANDS/TYPE OF PRODUCT
and perhaps if no sticky already exists mods....? :)
ENGINE OIL
4.7-4.9 litres inc filter, dry overhaul 5.5 litres, change 10k or under depending on use, 5w30 assuming standard engine spec
For higher mileage engines or motors that are munching some oil it is suggested to opt for a 10w40 semi-synthetic
- Fuchs Titan proS 5w30, Ester based API cert
- Standard option Motul 8100 Eco-nergy
- Fuchs Titan SYN MC 10w-40
ENGINE OIL FILTER
rule of thumb 3/4 turn by hand from point of gasket seating, 11-15 ft/lbs, with oil change
- Nissan 15208-9F60A
- K&N Gold HP-1008
SUMP PLUG & WASHER
22-29 ft/lbs torque, sump plug thread diameter 12mm, pitch 1.25, replace washer with oil change (crush washer)
- nissan washer 102601M02
- nissan drain plug 11128
- magnetic type plugs, gold plug Opie Oils (AP03) & other brands (Blox, Mishimoto, Greddy etc)
AIR FILTER
replace/inspect each service
- Apexi / Cosworth / HKS drop in panel filter
- Nissan OEM 16546-3J400
BRAKE FLUID
0.7-0.8 litres (buy 1 litre), change every 3yrs or 36k
- Motul RBF600 or RBF660 (min 3 dot)
- Nissan super heavy duty brake fluid
BRAKE LINES
- HoseTechnik
CLUTCH FLUID
0.7-0.8 litres (buy 1 litre), change every 3 yrs or 36k
- Motul RBF600 or RBF6600 (min 3 dot)
MANUAL TRANSMISSION GEARBOX OIL
manual 2.93 litres, fill plug/drain plug 23-28 ft/lbs, change 3yrs or 36k, 75w85 or 75w90 API GL-4
- RED LINE High Performance Synthetic MT-85 75W85 GL-4 Gear Oil
- Nissan MT-XZ Gear oil KE916-99931 or equivalent
DIFF OIL
1.4 litres, change every 3yrs or 36k, SAE 80w90 API GL-5
- RED LINE Synthetic Gear Oil 75W-90 GL5
- Nissan differntial Fluid KE907-99832 or equivalent
GEARBOX & DIFF PLUG/WASHER
do not need replacing unless lost, not crush washers
- nissan 110264N200
- aftermarket magnetic plugs?
POWER STEERING FLUID
1 litre
- Motul MULTI ATF Fluid
- Nissan PSF or equivalent
COOLANT SYSTEM
9.0 litres with resevoir, change every 3yrs or 36k, don't mix different coolant types..
- Nissan long life Antifreeze/coolant L248 Premix KE902-99945
ALTERNATOR/AC BELTS
change every 3yrs or when wear is detected
- Gates 4PK948 + 6PK1173 (don't bother with OEM belts, more expensive & slightly lower in quality)
SPARK PLUGS
gap (normal) in(mm) 0.043(1.1), change every 5 years
- Denso Iridium IKH16 x 6
WIPERS
change when you can't see anymore, 20" + 18" fronts, 18" rear
- PIAA if you're feeling flush
KEY FOB BATTERY
- CR2025
BULBS
- yes there are many refer to manual and/or source LED equivalents
Edited by mr_smith126
  • Like 5
Share this post
Link to post
Hi
There are a fair few I can add to that list.
Engine
http://www.opieoils....-653-5w-30.aspx
Fuchs Pro S, Motul 300V and Red Line are the best options, followed by the Castrol Edge, Mobil ESP, Millers EE and XF, Fuchs GT1 and Shell Helix Ultra Extra. The Motul Eco-Energy, Mobil Super 3000, Shell Helix HX7 AF/AG and Fuchs XTR are good cheaper alternatives.
If modified, you might need a 5w-40, but let me know the details.
Oil Filters
http://www.opieoils....er-2348400.aspx
http://www.opieoils....lternative.aspx
http://www.opieoils....oil-filter.aspx
Gearbox
Really, just this
http://www.opieoils....4-gear-oil.aspx
But, a lot of people have used 75w-80 and 75w-90 oils without issues, it depends on the driving style and climate.
Diff
The best option is a synthetic 75w-90, like the Silkolene Syn 5, Millers CRX NT LS, Motul Gear 300LS, Red Line 75w-90 GL5 or Gulf Competition LS. A SAE90 or 80w-90 mineral oil such as Motul 90PA, Fuchs Race Gear 90LS or Gulf Gear LS 80w-90 is a good, cheaper alternative.
http://www.opieoils....-slip-diff.aspx
Coolant
Motul Inugel Optimal, Fuchs Fricofin Long Life and Millers Alpine Red are good options.
http://www.opieoils....antifreeze.aspx
Brakes/Clutch
The best fluids for the brakes and clutch are the Castrol SRF, Motul RBF660 and Gulf RF1000. The Motul RBF600, Gulf RF800, Millers 300 Plus and Fuchs Pro Race are close to those, but don't have quite as high boiling points. Realistically, they are overkill for road use.The next step down (in performance terms), but still an upgrade over standard are the Gulf Racing 5.1, Motul DOT 5.1 and Castrol React Performance. Any of the other DOT4 fluids we have are fine to use as a standard choice.
http://www.opieoils....utch-fluid.aspx
Power Steering
You need an ATF and due to the required specs I would go for either the Motul Multi ATF, Fuchs ATF4400, Gulf Multi Vehicle ATF, Castrol ATF Multi Vehicle or Millers Millermatic ATF SPIII.
http://www.opieoils....c-442-atfs.aspx
Cheers
Tim
Edited by oilman
  • Like 6
Share this post
Link to post
Hi can someone report their experience with the Red Line MT gear oil.
Iv'e heard many mixed reviews, and many people saying sticking with the OEM oil to be best option.
Share this post
Link to post
Zmanalex and others have always recommended original gear oil with the addition of Molyslip. Had it in my gearbox and diff for the last 3 years and all good.
Sent from my Zed using Nangkang tyres front, RE040's rear
Share this post
Link to post
yes iv'e heard this from others too, based on all the forum threads iv'e read, going with Redline seems to be a risk (mixed opinions), where as the OEM with or without Molyslip a much safer route.
Heard many greats things about the 'With Molyslip' option.
Share this post
Link to post
Just as a quick feedback yesterday I did engine gearbox, diff and PAS fluid change.
Engine: 5w/30 Motul 8100
Gearbox: Motul Gear 300
Diff: Fuchs Silk Tran Syn5
PAS: Comma AQ3 ( can't find any PSF2 locally but recommended by comma own site)
The gear shift is noticeably smoother, less effort needed. Engine running smoothly and pullling stronger. Maybe that's down to new fluid effect but result are positive.
Thanks you to this list and Opie oil also, as it helped a lot during the research phrase as it is a mine field for selecting the fluid!
我從使用 Tapatalk çš„ Nexus 6 發é€
Edited by Carbon.Ninja
Share this post
Link to post
Everything still running fine and smooth?
Share this post
Link to post
Yea it is running good. Although I think I need to bleed the clutch again. As the there are some evil bubble still in the line but got rid of most since last flush.
Share this post
Link to post
Loading...
350z-uk.com
370z-uk.com
350z-uk.com
370z-uk.com
