370z JDM Style Classy Front and Rear Badges - One set only !!
Tarmac@TarmacSportz
Badges fitted today and they look sweet!
First thing is that I've just realised that the insert part of these badges matches the side z indicators which is a nice bit of symmetry.
Right getting the old ones off. I used the gfs hairdryer and fishing wire after failing miserably with dental floss.
Takes a bit of care and patience but I got there in the end.
Once you've loosened the sticky you can pull the old badges off. Just pull a section at a time and try not to lever the opposite edge of the badge into the paintwork.
As for fitting there's not much to say, take off the 3m cover and stick them on!
Make sure the small badge goes on the back and the big one on the front! And make sure they're the right way around before you fit.
Here's some early pics to have a look at. I'll get a few more up next week.
