Zeezeebaba Posted October 13, 2014 Posted October 13, 2014 My n/s compression arm bush is shot which I understand is a common issue. I have managed to source a genuine item for 280 but have seen a pair on ebay for 167. The ones on ebay are advertised as genuine and not Chinese copies and come with a 12 month warranty. Anyone else sourced them from eBay? I could replace one but would rather do both sides at once. The knocking is bad over bumps at low speed but due to work commitment s I can't get it done until next month. Hopefully I won't do much damage. Quote
Ewen@Clark Motorsport Posted October 13, 2014 Posted October 13, 2014 If its just the bush that's gone these can be replaced with a number of options. At £168 for a pair they won't be genuine Nissan Quote
Zeezeebaba Posted October 13, 2014 Author Posted October 13, 2014 Bush looks like it's pressed in from factory. Can they be removed with a standard press. What option would you recommend? Quote
Ewen@Clark Motorsport Posted October 13, 2014 Posted October 13, 2014 (edited) Yes mate they can be, we do OEM Nissan for £29.99 each which include fitting instructions, Whiteline push in fit for £69 for the pair or Superpro ones at £145 for the pair which are a press fit and give increased castor. We keep all the above in stock Edited October 13, 2014 by Clark Motorsport 1 Quote
ATTAK Z Posted October 13, 2014 Posted October 13, 2014 The ones from Ebay can't be guaranteed ... steer clear ... wait till next month and do the job once and properly 1 Quote
KUGT4 Posted October 13, 2014 Posted October 13, 2014 had to replace my split compression arm bushes - nissan only supply/fit the complete arms so purchased couple of oem nissan bushes from clark ms and had them fitted at local nissan for, iirc, around £100 total - around £160 1 Quote
Zeezeebaba Posted October 13, 2014 Author Posted October 13, 2014 Cheers for the input guys, I will be in touch at the end of the week. Quote
