My n/s compression arm bush is shot which I understand is a common issue. I have managed to source a genuine item for 280 but have seen a pair on ebay for 167. The ones on ebay are advertised as genuine and not Chinese copies and come with a 12 month warranty. Anyone else sourced them from eBay?
I could replace one but would rather do both sides at once. The knocking is bad over bumps at low speed but due to work commitment s I can't get it done until next month. Hopefully I won't do much damage.
Posted (edited)
Yes mate they can be, we do OEM Nissan for £29.99 each which include fitting instructions, Whiteline push in fit for £69 for the pair or Superpro ones at £145 for the pair which are a press fit and give increased castor.
We keep all the above in stock :)
Edited by Clark Motorsport
had to replace my split compression arm bushes - nissan only supply/fit the complete arms so purchased couple of oem nissan bushes from clark ms and had them fitted at local nissan for, iirc, around £100
total - around £160
