SamN Posted August 1, 2014 Posted August 1, 2014 Hi guys, When I press the button to open my fuel cap it 'pops' but doesn't open any more, prpbably opens 1-2mm... I had a quick search around and didn't find the solution. Any ideas? Cheers Sam Quote
richard.hezlett Posted August 1, 2014 Posted August 1, 2014 Spray wd 40 in where the plastic pin pulls back to free cap if you can get it open. Plastic pin starts to stick over a period of time. Quote
longsh07 Posted August 1, 2014 Posted August 1, 2014 Mash button repeatedly in quick succession Mine has only gotten stuck once or twice. Once its open just spay a little WD40 on the latch and clean off any muck. Quote
leonk Posted August 1, 2014 Posted August 1, 2014 If you ever get stuck you can open it manually from inside the boot behind the trim panel. 1 Quote
Roland Rat Posted August 1, 2014 Posted August 1, 2014 Same happened to me today, only problem is pushed the release a bit to hard and the switch went back through the dashboard !!!! Oh well something else to fix!! 1 Quote
Martinjj Posted August 1, 2014 Posted August 1, 2014 Same happened to me today, only problem is pushed the release a bit to hard and the switch went back through the dashboard !!!! Oh well something else to fix!! i did that 2 days ago... its a bugger to get back in if you've got fat fingers... 1 Quote
WhackyWill Posted August 1, 2014 Posted August 1, 2014 WD 40 and don't be lazy, mine only opens about 3/4 of the way... then flip it open the rest of the way.. Quote
