Help my sub
Zhorno
Randomly was working other day fine , I'm in it now and nothing all standard , any ideas ?
You're in it now ? what are you in ? the sub ? ... I'm impressed ... not many people on here got a submarine ;)
Yes mate just that. Helps if you have a friend because when you remove the iron, the solder sets again immediately. You need someone to pop the leg out whilst you have the solder in its liquid state, or do as I did on the guide and get it done by snapping the relay off and use some pliars to pull put the legs.
  • 3 weeks later...
I never bothered buying a relay, all I did was wrap a load of insulating tape around it, put it all back together and 18 months later I'm still getting a free back massage, but then again I'm the sort of guy who turns his underwear inside out, so you could say I'm a bit of a tightwad. I'm a tightwad, there you go!!
