Tarmac@TarmacSportz Posted June 2, 2014 Posted June 2, 2014 (edited) 350Z Bonnet Dampers £55 plus £6 delivery So here are some close ups of all the component parts Really straight forward to fit, remove the brake fluid and battery covers together with their surrounds. Remove the two bolts (one either side of the engine bay) discard these and remove the front most nut on the bonnet hinges. Fit the the top mounts onto the bonnet hinge bolt. Fit the top fixings of the dampers to the new top mounts. Use the countersunk bolt (more about this in a bit) to secure the lower damper mounts to the front wings, these replace the two bolts discarded earlier. Fit the the lower damper fixings to the lower mounts and replace the brake fluid and battery cover plastic surrounds. The surrounds fit perfectly over the lower fixings because of the countersunk bolts, so no need to trim plastic surrounds to fit. I also like the non metallic ball joints receptacle so very little chance of rust as experienced with other kit. A doddle to fit, took me no more than half an hour or so, all in all seems like a good bit of kit Edited March 28, 2017 by Tarmac@TarmacSportz Quote
HAMLNJ Posted June 2, 2014 Posted June 2, 2014 Want want want!!! Can you pm me your paypal details and I'll get my address and payment to you. Bolt in with no cutting yeah? Quote
Flex Posted June 10, 2014 Posted June 10, 2014 Why oh why didnt you have these when I bought the Tein ones that are a real ball acher to fit? Sigh. Will you take some Tein ones in px Quote
Tarmac@TarmacSportz Posted June 10, 2014 Author Posted June 10, 2014 Use the clips from these and the bars from Teins Thats what Glrnet did Quote
HAMLNJ Posted June 10, 2014 Posted June 10, 2014 Delivered in record time! I came to work at 8.50 and my boss already signed for them!! Look like solid bits of kit. Nice little job for after work tomorrow. Cheers Chris!!! Bit more money in my back pocket and I'l be back in touch for some other bits!! Quote
Flex Posted June 10, 2014 Posted June 10, 2014 Use the clips from these and the bars from Teins Thats what Glrnet did Can you supply them separately Chris? Quote
Tarmac@TarmacSportz Posted June 10, 2014 Author Posted June 10, 2014 Lol, no bud. You would have to buy the whole unit Quote
HAMLNJ Posted June 11, 2014 Posted June 11, 2014 Not sure if those photos are a bit backwards or I am but they seem to show things the wrong way around. First attempt the bonnet didn't lift all the way up. For a novice it can be left and right as you look at the car or the other way round. These photos seem to show as you look at the car. The top mounts in the pictures seem to be fitted wrong. But... I might of just got it completely wrong...I am a complete novice. Quote
14N Posted June 11, 2014 Posted June 11, 2014 Not sure if those photos are a bit backwards or I am but they seem to show things the wrong way around. First attempt the bonnet didn't lift all the way up. For a novice it can be left and right as you look at the car or the other way round. These photos seem to show as you look at the car. The top mounts in the pictures seem to be fitted wrong. But... I might of just got it completely wrong...I am a complete novice. Good point, they are. The 'L' and 'R' refer to when you're in the car as opposed to looking at it from the front. Quote
HAMLNJ Posted June 11, 2014 Posted June 11, 2014 Nearly threw the spanner at the wall half way through lol Quote
bc1987 Posted August 4, 2014 Posted August 4, 2014 Do these open the bone higher than with the metal pole? Quote
Tarmac@TarmacSportz Posted August 4, 2014 Author Posted August 4, 2014 Graham can confirm but I think its about the same height Quote
bc1987 Posted August 4, 2014 Posted August 4, 2014 Go on then can you add them to my pile of bits to collect? Quote
Tarmac@TarmacSportz Posted August 4, 2014 Author Posted August 4, 2014 Go on then can you add them to my pile of bits to collect? Sure buddy Quote
steve916 Posted November 1, 2014 Posted November 1, 2014 Hi. Will these fit the HR bonnet? If so, have you got any in stock please? Quote
steve916 Posted November 1, 2014 Posted November 1, 2014 They do fit the HR bonnet That's great. Thanks Quote
philw99 Posted November 2, 2014 Posted November 2, 2014 Finally ordered the bonnet dampers 😃 Sent from my iPad using Tapatalk 1 Quote
