Hi just wondered if any 350 owners had come across there passenger window partially opens and does anybody know of a fix...cheers
The fault on mine seems to be every so often may be 1 in every 20 times a passenger gets in and shuts the door the window seems to drop a couple of inches....very annoying
Before doing a full reset just disconnect the negative terminal on the battery for a few minutes then reconnect, I did this and rectify the same issue with my window. Best to try before taking of door panels and that.
Its funny u shud say that...abt 6 months ago my batt went flat n eversince i had it replaced nothing but trouble so thank u very much for the info...will try it tomorrow and let u kno wot happens one again many thanks
Why is this in announcements?
Been moved now by the mods. ;)
Just another new person posting in the wrong section, ...at least it gives the mods something to do I guess. :lol::D
Before you get the sockets out, take 2 mins to just tweak the door close nipple in the shut a few times and see if the window leaps up and down. Mine misbehaved for a while and caused the window to misbehave.
Sticky nipple Stu ?
Sticky nipple Stu ?
I think it just got gummed up, some sort of fluid discharge or build up :lol: once I gave it a clean it was back in working order!
