smudgedon Posted April 17, 2013 Posted April 17, 2013 Changing out the rear studs on the zed, calipers off and trying to get the disc off th hub now Should it just come off with a bit of force? I don't have to remove the large hub nut in the middle do I? Quote
370Ad Posted April 17, 2013 Posted April 17, 2013 Nope, my discs were very stuck on so it requires some force! Quote
Sly@Kaizer Motor Posted April 17, 2013 Posted April 17, 2013 Hammer and hope that's all you need Quote
gareth29 Posted April 17, 2013 Posted April 17, 2013 aren't the shoes for the hand brake inside the hub? - if so you will need to release the handbrake and back the shoes off first Quote
Sam Mcgoo Posted April 17, 2013 Posted April 17, 2013 aren't the shoes for the hand brake inside the hub? - if so you will need to release the handbrake and back the shoes off first Yes, you'll need to wind the adjusters on the handbake shoes to release them from the disc hub before you batter it off. Quote
smudgedon Posted April 17, 2013 Author Posted April 17, 2013 Handbrake off and a lot of grunt did it in the end Quote
The Bounty Bar Kid Posted April 17, 2013 Posted April 17, 2013 You managed to get through your list of stuff to do? Quote
smudgedon Posted April 17, 2013 Author Posted April 17, 2013 You managed to get through your list of stuff to do? Most of it, will update my thread later Quote
