Rear hub assembly help ASAP
Changing out the rear studs on the zed, calipers off and trying to get the disc off th hub now
Should it just come off with a bit of force? I don't have to remove the large hub nut in the middle do I?
aren't the shoes for the hand brake inside the hub? - if so you will need to release the handbrake and back the shoes off first
Yes, you'll need to wind the adjusters on the handbake shoes to release them from the disc hub before you batter it off.
