Running a cable from engine to cabin
Just wondering what is the best/easiest way to run a cable from the engine bay into the cabin? Is there a hole already in the bulk head that can be used? If so where should I go looking?
I'm planning on using the cables as the loom for an oil temp gauge.
Thank you
Steve
I go through the battery compartment, easy to reach from the passenger footwell area. if you remove the plastic trim below the windscreen in the battery area you will see where the loom enters through.
  • Like 2
Where are you mounting your gauges ?
The reason I ask, is mine are on the drivers A-pillar and cubby so went in on the drivers side for a shorter run.
There is a big rubber grommet just behind the ABS module that brings you into the drivers foot-well behind the dash.
Can be seen in the far left corner of this pic. -
