I thought i would put up my build thread so far of the 200sx, as we are all petrol heads and like to see some insperation for modifications, i am new to the site but hope you all follow my thread i will be keeping it as upto date as possible :)
And so it begins, i went and collected my new car a couple of days ago, i completed the PX deal with my Audi and away home i drove from Leeds
Now the current spec
Block:
ACL main bearings
ACL con rod bearings
ACL thrust washers
ARP main bolts
ARP con rod bolts
ARP head studs
HKS 1.2mm metal head gasket
New GTI piston rings
Head:
Skimmed
Cleaned
Pressure tested
Valves cleaned, lapped and new VSS's
Engine misc...
New gaskets and seals all round!
Custom blue painted rocker cover
Blue silicone coolant hoses
Stage 4 paddle clutch from compitition clutches
Induction:
Apexi dual cone filter
Apex Type 2 FMIC and piping
Turbo/manifold
Stainless steel manifold ( unsure of make)
New Nissan manifold to head gaskets
New turbo to manifold gaskets
Studs welded to manifold and lock washer and nuts to stop the turbo coming loose/blowing
Blitz bov
Fuelling...
Walbro fuel pump
Stock injectors, flow checked
Exhaust...
Japspeed Stainless steel 3" exhaust elbow (s14a)
Stainless steel decat (345mm)
Apex cat back exhaust ( new)
Suspension/ brakes / steering wheels
Stock shocks with 30mm apex lowering springs
Apex poly steering rack bushes
R33 skyline GTST front brakes with new ebc discs and pads
Front calipers refurbed
Driftworks braided brake lines all round
350z nismo forged 18" alloys
Electronics
Blitz Uras SBC
Sony head unit
Exterior
Clear front indicators ( genuine Nissan)
Clear side repeaters
Touring side skirts
Led side lights
HID dip beam
she came with a horsham dev stage 1a chip which is in now, once the boost is set up she should be running 285bhp and 300fb.
couple of pictures of the car and the next stage :)
i had to think about where i wanted my 60mm Apexi boost gauge mounted so i have come up with this little solution, wanting to make it look like it was meant to be their.
smoothed the body filler and then applied a celly solution to get rid of the pin prick holes
the dash sections will be getting sent for Flocking now so they should look nice and OEM+ :)
Cheers Guys,
Parts are now away to be flocked, got three days off next week to get the boost issue sorted, stripping down the turbo and porting the wastegate and fitting a silenced decat to create a bit of back preasure to help with the internal wastegate exhaust flow, this should .. touch wood ... make the boost a steady 7psi until i get my head round my Boost controller. :)
in the meen time.. dont know if any one has seen but the 350z Rays are now on ebay :)
http://www.ebay.co.uk/itm/230860790612? ... 1555.l2649
cheers chaps right very small update
Well flocking pictures as promised, have to wait 24hours for it to dry but once they are dry they will be going back in to my car :)
