Hi All ! Some performance questions
Hi all Ive just joined the forum after finally getting a Zed :yahoo: Its a totally standard 04 plate with under 10k on the clock and iam delighted with it.I traded a T sport celica so you can imagine the difference!!! I now wanna treat her to some extra performance but Iam a complete lamer regards upgrading etc....What do you Guys think I should do first / best place to get stuff /fitting etc would be really gratefull for any advise cheers...
Hi there, you will not be dissapointed with the Zed, if you do a search on this site you can find lots of bolt on stuff for the car reviewed etc.. Sorry no real gains in power with air filters , exhausts etc but they do make the car sound better :thumbs:
The only easy power gain can be achieved by installing a plenum from Kinetix or some other company to get increased airflow. Apart from that it will be F/I which will cost you lotsa money :p
Any pictures?????
Welcome aboard buddy :thumbs:
I wouldn't say the standard exhaust is shocking compared to most standard fit exhausts. I think it's pretty good.
:welcome: by the way
+1 (Nismo's better though... :teeth: )
Welcome, MuzBain! :thumbs:
Oh I agree Digsy, just don't think the standard one is that bad as it's mad out to be. It's far better than any other car in its class until you start getting up to to 911 territory
Yup, and I was agreeing with that. :teeth:
Wow thanks for all the advice really helpful ive seen a typhoon induction kit for 100 notes so thought might get that Ive got a couple of niggles with my zed changing first into second is a bit difficult and there is noise when i brake /pull away like something loose at back axle area still under garage warrenty so gonna get them to check it out
notchy gear change when cold is normal, crunchy gears aren't.
The noise you hear is probably clucky rear axles, your dealer should know, do a search on here to learn more :thumbs:
It is pretty good as a stock zorst but the difference with a Nismo is magnificent!!! It was so different infact that 30 mins after fitting it I thought i couldn't live with it. Then I saw the light B)
Had the same "Road to Damascus" experience myself! :teeth:
The new growl still suprises me everyday. 5k+ rpm's and its almost a sexual experience!!! :D
It's good but I think you must be doing the sex bit wrong, lad! :p
