Jakedd Posted June 23, 2012 Posted June 23, 2012 Before I hack at the current wheel badges with a screwdriver, does anyone know how to remove the centre wheel badges? I'm hoping they'll pop out with a screwdriver? Thanks Quote
Stew Posted June 23, 2012 Posted June 23, 2012 I think it's easiest to pop off from the back. Remove the wheel and they should push out. Not sure if it's easy to get them off without the wheel removed. Quote
Jakedd Posted June 23, 2012 Author Posted June 23, 2012 Right, cheers. That slight MOD will have to wait till Monday..... Quote
neo Posted June 23, 2012 Posted June 23, 2012 yeah the wheels need to be remove and then they just pop out, had mine done years ago when i had new tyres all round Quote
rtbiscuit Posted June 23, 2012 Posted June 23, 2012 if your lazy and never wanted to use the old wheel centres, you can always glue some sticks to the centres let dry and then they should pull out the centres. needs to be good glue. and need plenty of surface contact. Quote
MDMetal Posted June 26, 2012 Posted June 26, 2012 I just pulled them out by the badges! That said the ones I pulled off were missing the wire ring that gives them a bit of resistance and I was replacing them so wasnt too bothered if they broke. Quote
p40ulw Posted June 26, 2012 Posted June 26, 2012 Use a plunger and suck'em off is it really that easy? Quote
