Vinyl wrapping the engine cover?
Madhatter
vinyl will withstand the heat, the decals i've done for brake calipers hold up fine to the heat.
the issue you might have is if the heat soften the vinyl and makes it move/lift reshape etc. decals are fine as they are flat, but your going to be stretching it to fit.
