Rattly Thing On Top Of Dashboard
Martin S
I know this is a very trivial matter, but if you heard it in your car you'd want to fix it too!
The little round bit of plastic on top of the dashboard on the drivers' side, with the alarm l.e.d. in, sometimes buzzes/rattles very loudly!
The noise stops if I lightly put a finger on it.
Has anyone else had this, and if so how did you cure it without stripping the dash or using unsightly sticky tape..?
(2003 350Z).
Thanks.
  • 11 months later...
It's usually the dash v windscreen that makes that noise. Probably just need a bit more high density foam squeezed in between dash and the windscreen.
+1 common fix to a common problem :thumbs:
Colder weather makes things worse - an issue not just ZED related but on many cars that use plastics in the dashboard area :shrug:
