Where is this part going on the engine?
andlid
I can't figure out where this part goes on my engine, the photo gives little away on where it might be. I could prolly thrawl through 100 pages manual to find it but wondering if someone has the answer to hand?
got a different plenum on and just can't make out where this is... :blush:
That picture is off the front left hand corner of the plenum as you look at it - the pipe connects to the lower plenum - can fid out where the other end goes if you like but I think it goes to the vacum line that runs with the petrol feed pipe - would need to double check that last bit to be sure.
Hope that helps. :blush:
^^ My setup :)
Left hand pipes - One goes to the rear of engine (There is a hose there that goes under the TB to the intake pipe), the other goes to the plenum & once you remove that hose then you block the other side off.
Right hand pipe - Goes into the free connection under the intake pipe
Omg just done a schematic of my current setup (below)
^ that's obviously arseways, thank you for installing it that way... :rant:
This is the way it should be:
:bang:
So just hoping that mr nogood has kept my spares in the bag so I can yet again rectify another thing not right...
(thanks Ian for the pointers)
What is the actual impact on this? :wacko:
