GT4 Zed Posted February 5, 2010 Posted February 5, 2010 Anyone please tell me how to change the power steering fluid. I can't seem to find a drainage or bleed point while underneath the zed most of today sorting my A camber arms and adjusting the suspension There is no DIY guide in the service manual or 350 z tech wiki and i wouldn't want to create and air lock by going at it gong-hoo stylee!! cheers Quote
Stew Posted February 5, 2010 Posted February 5, 2010 I think the lowest point in the system would be the lower connector on the cooler. No idea though on changing the fluid though, I've had to top up once never changed it out. Quote
scottsoulby Posted February 5, 2010 Posted February 5, 2010 I've just changed my cooler as it was leaking, I'm sure if you just disconnect the bottom hose on the cooler it will all drain out, as for air locks, once you filled it up, start the car without the lid on and keep turning wheels to full lock each way a few times, that should get rid of any air in the system Quote
rtbiscuit Posted February 5, 2010 Posted February 5, 2010 never heard of a drain and change on steering pump fluid, only ever top ups Quote
ZMANALEX Posted February 5, 2010 Posted February 5, 2010 No requirement to change PAS fluid, only top up, but if you still want to change then as above. Quote
GT4 Zed Posted February 5, 2010 Author Posted February 5, 2010 Cheers guys i just feel safer changing it with higher performance a one as i am going to be running even bigger wheels on the front axle. i will also be putting the nismo upgrade cooler to keep things cool Quote
