Dblock Posted January 21, 2010 Posted January 21, 2010 Hi I bought a Uk spec battery and terminals. I have a 02 JDM. Does anyone know if it slots straight in or there is tinkering to be done? Thanks Quote
Dblock Posted January 22, 2010 Author Posted January 22, 2010 Anyone? Even if you have a pic of a uk battery wired up that would be ok. Thanks Quote
Stew Posted January 22, 2010 Posted January 22, 2010 I think Lomoto did this. Have a search through his posts and the guides. Quote
choptop Posted January 22, 2010 Posted January 22, 2010 Ian may also be able to help on this one Quote
Anubis Posted January 22, 2010 Posted January 22, 2010 You could dismantle the whole car and then build it again around the battery. This is a long way around though... Quote
gunmetalzgt Posted January 22, 2010 Posted January 22, 2010 You could dismantle the whole car and then build it again around the battery. This is a long way around though... Very helpful im not any better im afraid Quote
Dblock Posted February 2, 2010 Author Posted February 2, 2010 So the battery fit like a charm. I used a 005L which is a uk battery. You need to change the terminals but if you have a JDM then its worth it. no more 3 days and your battery goes flat and it starts so quick now. Quote
choptop Posted February 2, 2010 Posted February 2, 2010 So the battery fit like a charm. I used a 005L which is a uk battery. You need to change the terminals but if you have a JDM then its worth it. no more 3 days and your battery goes flat and it starts so quick now. Where did you get if from? How much was it? I am sure other members could use this info for when their battery goes wrong Quote
yeti Posted February 2, 2010 Posted February 2, 2010 So the battery fit like a charm. I used a 005L which is a uk battery. You need to change the terminals but if you have a JDM then its worth it. no more 3 days and your battery goes flat and it starts so quick now. Where did you get if from? How much was it? I am sure other members could use this info for when their battery goes wrong Are jdm batterys really bad? My UK battery lasted 3 years and 37k then gave up. Bit crap really, my old GTI battery lasted 9 years! I replaced it with a bigger halfords battery for my corrado that i had lying around on charge. 50mm too wide (i think the standard one is 230mm) but it just fit in and works Quote
Dblock Posted February 2, 2010 Author Posted February 2, 2010 So the battery fit like a charm. I used a 005L which is a uk battery. You need to change the terminals but if you have a JDM then its worth it. no more 3 days and your battery goes flat and it starts so quick now. Where did you get if from? How much was it? I am sure other members could use this info for when their battery goes wrong Are jdm batterys really bad? My UK battery lasted 3 years and 37k then gave up. Bit crap really, my old GTI battery lasted 9 years! I replaced it with a bigger halfords battery for my corrado that i had lying around on charge. 50mm too wide (i think the standard one is 230mm) but it just fit in and works Yes it is. Its like half the size of the uk battery. Its only got 330cca! Quote
ChrisS Posted February 2, 2010 Posted February 2, 2010 So the battery fit like a charm. I used a 005L which is a uk battery. You need to change the terminals but if you have a JDM then its worth it. no more 3 days and your battery goes flat and it starts so quick now. Where did you get if from? How much was it? I am sure other members could use this info for when their battery goes wrong I bought a 005L on Friday, for a UK car though. I'm in rural Wales so ordered it localy,so usualy a bit dearer !. (Thurs ready for Fri) It was a Varta 005L D47 2 year guaranty £53.50 VAT = £62.86 Fitted today,tis brill the other was the original Nissan from new. Saw some On-line for £45.00.................... WAS NOT SURE RE THIS so went local. It's where to get the terminals I think would be better info for JDM owners. Chris Quote
3FIDDYZ Posted February 2, 2010 Posted February 2, 2010 Were all old gits on here and our memory has faded so we probably cant be much help... Quote
3FIDDYZ Posted February 2, 2010 Posted February 2, 2010 In all seriousness I would ask.... oh bugger who was it... erm.. As hes done it... right on the tip of my tongue...erm... Thats it.. Dcash5 Quote
IanS16 Posted February 2, 2010 Posted February 2, 2010 JDM batteries aren't THAT bad! I've only had to charge mine once (in Jan when it snowed for a week) and its been off the road for about 6 months. I think you guys have just been using crap batteries Quote
Dblock Posted February 2, 2010 Author Posted February 2, 2010 JDM batteries aren't THAT bad! I've only had to charge mine once (in Jan when it snowed for a week) and its been off the road for about 6 months. I think you guys have just been using crap batteries Hmm your lucky. My battery was a delphi and it never seemed to good. The terminals I got from R35Lee but im sure ZMANALEX could hook you up. The UK battery was cheaper than a jdm one aswell. Quote
IanS16 Posted February 11, 2010 Posted February 11, 2010 Sorry to bump an old topic but I started my car today after a few weeks so I thought I'd have a look at which battery I had. Just for other people who may be wanting a new battery I've got the Bosch asiaSILVER 12v 40Ah 330a model number 540126033. Definitely gets my vote Quote
Dblock Posted February 11, 2010 Author Posted February 11, 2010 Why do JDM's have such small batteries? The uk spec has 660cca and is 68AH or mine does. My old Delphi one was the same rating as that bosch one. Bosch batterys are good batteries though. Quote
