clicking noise on door hinges
hotrain69
I get the same clicking/creaky noise too on my driver door. Don't get it on the passenger door. Nothing is loose. I was thinking of maybe spraying some oil wd40 on the hinges at the weekend and seeing if that helps. Unless anyone has solved this before with something else?
Just checked and I can see the noise is indeed coming from the black plastic bit where there is a small nut in the middle of, actually on the car itself where the door hinge attaches to the body - the black plastic keeps slipping slightly side to side when the door is opened (if you open up the door you will see it towards the top). I was thinking about simply tightening the nut up to see if that helps. May try when a bit lighter. It may not work as there is no way for me to get behind the metal in case there is another nut on the other side which I'd have to hold while tightening. I'll see.
