Small irritating vibration in passenger compartment
Hi all
Wonder if anyone has had the same or can shed some light on this matter.
A small vibration noise that is driving me mad is coming from the passenger compartment, possibly the door interior? any ideas. It stops if i press lightly against the door. Mainly on uneven road.
cheers Paul
The door card may have been removed for a window winder issue, some of the poppers may not be locating properly or may have been broken when removed, a gentle tap with your fist could cure it if you can find the vibration.
Check to make sure the screws are in place too...
3FiddyZ is most likely right but also the glass in mine on the passenger side rattles against the door. If the window is fully done up its not so bad but open it by a few mm and it rattles like crazy. Doesnt do it if I lean on the door slightly.
Best bet would be to remove and refit the door card, checking that all internals are attached and not loose.
Also my passenger seat belt makes a hell of a racket if its not located in the plastic clip on the door pillar.
Also, if its an 07> car, then there could be something lose in the bottle holder int he door card.
This had me banboozled for a while earlier int he year.
