toffeeman Posted July 19, 2008 Posted July 19, 2008 I've read all the info on the infamous "clicking axle" syndrome that the Zed suffers from and would like to fix mine. Does anybody know if there is a UK supplier that supplies the full kit to fix the problem? I've looked through this site and read pretty much all there is on the subject but cannot find a definitive supplier. I can find plenty in the States that supply repair kits and uprated axles but would prefer a supplier closer to home. Any ideas? Craig. Quote
Zummertor Posted July 19, 2008 Posted July 19, 2008 Not kits per se, but you can get the parts list of the TSB list available on here, search away. Quote
martinmac Posted July 19, 2008 Posted July 19, 2008 Bigphil was looking at getting a price for a fix together, may be woth PMing him. In the meantime heres the TSB link. http://www.350z-tech.com/zwiki/TSB_04-0 ... _Rear_Axle Quote
toffeeman Posted July 19, 2008 Author Posted July 19, 2008 Thanks for the replies guys. I've read the TSB many times. I was trying to get an all encompassing kit as opposed to fannying around with numbers for clips and washers and things. I'll PM Phil as recommended. Cheers, Craig Quote
GIXXERUK Posted July 19, 2008 Posted July 19, 2008 also try kev at envy, he was looking at putting a repair kit together Quote
toffeeman Posted July 19, 2008 Author Posted July 19, 2008 also try kev at envy, he was looking at putting a repair kit together Will do. Thanks for the tip. Quote
dcash5 Posted July 19, 2008 Posted July 19, 2008 Keep everyone updated on your progress would be interesting for many members including me Quote
toffeeman Posted July 20, 2008 Author Posted July 20, 2008 Keep everyone updated on your progress would be interesting for many members including me Yeah, no problem. I've not heard anything back from Big Phil or Kev from Envy Performance but I'm not expecting anything until after the weekend. Quote
Gus Posted July 20, 2008 Posted July 20, 2008 Give Chris at JDM Performance ( user name JDM Performance ) a PM - he knows all the parts required, normally keeps them in stock in the UK, and is approx 20% cheaper than Nissan dealer prices. Quote
M13KYF Posted July 21, 2008 Posted July 21, 2008 Give Chris at JDM Performance ( user name JDM Performance ) a PM - he knows all the parts required, normally keeps them in stock in the UK, and is approx 20% cheaper than Nissan dealer prices. +1 he's doing the kits Quote
toffeeman Posted July 21, 2008 Author Posted July 21, 2008 Give Chris at JDM Performance ( user name JDM Performance ) a PM - he knows all the parts required, normally keeps them in stock in the UK, and is approx 20% cheaper than Nissan dealer prices. Gus, Cheers for the heads up. I've PM'd him. Craig. Quote
toffeeman Posted July 22, 2008 Author Posted July 22, 2008 I've received a response from JDM Performance below..... Hi We dont have a 'kit' as such, but to fix it (on both sides) you need: Dust Boot Repair Kit 2 of these at £30 each Axle Outer Joint Assembly 2 of these at £120 each Rear Wheel Bearings 2 of these at £55 each They reckon that lot above at £410. Does anybody know exactly what component causes the clicking problem? I don't see why I would need to replace the wheel bearings as the car has only done less than 25k miles. In my previous experience wheel bearings tend to screech / squeal as opposed to clicking. I'm wondering if its just the Axle Outer Joint Assembly component that clicks. Any ideas?? Craig. Quote
GIXXERUK Posted July 22, 2008 Posted July 22, 2008 wheel bearings generally drone when under load if their knackered cant see why they would need changing i would guess that the outer axle joint assembly is splined where it fits to the hub, and the lash in the splines causes the click Quote
toffeeman Posted July 22, 2008 Author Posted July 22, 2008 wheel bearings generally drone when under load if their knackered cant see why they would need changing Yeah, I totally agree. The clicking doesn't fit with a duff wheel bearing, as you say they generally make noise under load. Quote
GIXXERUK Posted July 22, 2008 Posted July 22, 2008 wheel bearings generally drone when under load if their knackered cant see why they would need changing Yeah, I totally agree. The clicking doesn't fit with a duff wheel bearing, as you say they generally make noise under load. have you downloaded the manual mate ? http://www.350z-tech.com/zwiki/Category:Service Quote
toffeeman Posted July 22, 2008 Author Posted July 22, 2008 wheel bearings generally drone when under load if their knackered cant see why they would need changing Yeah, I totally agree. The clicking doesn't fit with a duff wheel bearing, as you say they generally make noise under load. have you downloaded the manual mate ? http://www.350z-tech.com/zwiki/Category:Service I have now. Thanks. Quote
Ian Posted July 22, 2008 Posted July 22, 2008 Is it just the rears that click? My car has an annoying click from the front passenger side since I fitted my sway bars (I think its an endlink problem though) Quote
toffeeman Posted July 22, 2008 Author Posted July 22, 2008 Is it just the rears that click? My car has an annoying click from the front passenger side since I fitted my sway bars (I think its an endlink problem though) Yeah, I'm pretty sure that this particular problem is for the rears only. I did find this whilst googleing the part number for the Axle Outer Joint Assembly (39211-73L00). Clicking noise from rear. Drivers of some 2003-04 350Z sports cars (complete application list below) may complain of a clicking sound emanating from one or both rear axles when the vehicle is accelerated from a stop. Nissan attributes the noise to a dried out or prematurely worn outer CV joint. A new-design, more durable joint (Part No. 39211-73L00) is now available to solve the problem. When installing the new joint(s), the Japanese carmaker also recommends replacing the rear wheel bearing(s) with Part No. 43210-AL505. Vehicles that are prone to the clicking noise and can benefit from the upgraded CV joint include all 2003 models; 2004 convertibles built prior to VINs JN1AZ36A*4T014269 and JN1AZ36D*4T110452; and 2004 model coupes built before VINs JN1AZ34D*4M100248, JN1AZ34E* 4M150167, JN1AZ34D*4T164501 and JN1AZ34E*4T063336. I did want to know if the new joints are upgraded so that the problem wouldn't reappear in a couple of years time. It appears they are. Quote
toffeeman Posted July 24, 2008 Author Posted July 24, 2008 Does anybody know if there is an equivalent grease to MOLYKOTE M77 as a 1kg tin costs £118? This is what Nissan recommend for the CV Joints. Quote
