Steering sluggish - new steering rack required?
Blimey it's taken ages to be able to log back in here, had to create a new account too!
So my GT4 power steering has become a bit weird. When you crank the wheel over it's not too keen to try and centre itself like it would if the steering was light, so the car has a tendency to drift left or right, and the steering is generally heavier than before.
I had the garage fit another p/s pump but that hasn't changed the issue. The garage did say they didn't think there was anything wrong with the pump before hand, they think it's the rack. I tried the pump first just to be sure.
Is there any other likely culprit or am I really looking at another rack? The car has done 32,000 miles. No idea how long a rack should last but probably longer than that. Is this a case for zmanalex then?
I’ll assume they changed the fluid when they changed the pump?
Ultimately it’s a 20 year old car that’s not really been used, so sat around a lot of the time which isn’t a great thing. I’d expect a rack to last longer too, but only under normal use.
