Hi,
My drivers side window stopped working and could only get it back to the up position by banging the door whilst pressing the up button
I assume this would be the motor and not the regulator? If motor eBay seems to have very cheap ones;
https://ebay.us/m/usoO6l
Has anyone purchased one of these before? OEM is ridiculous but Torqen does a rev spring one which is more reasonable but still not cheap.
Cheers
I don't know about 350zs but I've had electric motors on older cars where the grease inside the gears has been old thick and crusty; and after a a strip down, wash and new grease was fine.  I've also had occasions where it's been tired and worn reed switches on the switch circuit board at fault not the motor or regulator.  Also a failed capacitor on the circuit board.
OEM pre-owned fully working motors are in stock, however the eBay ones work as I have used them in the shop on numerous occasions.
