Jap350 Posted June 16, 2023 Posted June 16, 2023 Hi, I’m new to my 350 I knew about the problem when I bought the car. The mechanical emergency cord works for the boot but the button under the license plate does nothing. No noise or anything. Is it possible just to have a faulty switch and if so does the rear bumper have to come off to look at it ?? Quote
ShortPaul Posted June 17, 2023 Posted June 17, 2023 Hi buddy it's most likely to be the boot popper springs Quote
Jap350 Posted June 18, 2023 Author Posted June 18, 2023 The button makes no noise though and even with 2 people it won’t open from the button ? Quote
Jay カレー Posted June 18, 2023 Posted June 18, 2023 Interesting, I have exactly the same issue. I can’t see why it would be the popper springs as when you pull the cable it “pops” up nicely?.. I’ve just ordered a used boot latch off eBay so will let you know if that works. 1 Quote
Jap350 Posted June 18, 2023 Author Posted June 18, 2023 1 minute ago, Jay カレー said: Interesting, I have exactly the same issue. I can’t see why it would be the popper springs as when you pull the cable it “pops” up nicely?.. I’ve just ordered a used boot latch off eBay so will let you know if that works. That would be great thank you 🙏 1 Quote
Payco Posted June 19, 2023 Posted June 19, 2023 PM Zmanalex for advice and spares for your Zeds boys.. 1 Quote
Luigi350z Posted June 19, 2023 Posted June 19, 2023 On 16/06/2023 at 20:41, Jap350 said: Hi, I’m new to my 350 I knew about the problem when I bought the car. The mechanical emergency cord works for the boot but the button under the license plate does nothing. No noise or anything. Is it possible just to have a faulty switch and if so does the rear bumper have to come off to look at it ?? I had the same issue and, like you said, it was the button under the license plate. Unfortunately , you need to remove the rear bumper to change it. In my case, it was a good idea doing the work after having already purchased the entire used part because mine was a bit rusted/ruined (not just the switch but also its supports) Quote
Jap350 Posted June 19, 2023 Author Posted June 19, 2023 26 minutes ago, Luigi350z said: I had the same issue and, like you said, it was the button under the license plate. Unfortunately , you need to remove the rear bumper to change it. In my case, it was a good idea doing the work after having already purchased the entire used part because mine was a bit rusted/ruined (not just the switch but also its supports) Where did you get it all from a scrap yard or eBay ext? Quote
Luigi350z Posted June 19, 2023 Posted June 19, 2023 Unfortunately Zmanalex didn't have it, so I bought it from eBay (USA). Quote
