Lynchyy Posted October 5, 2021 Posted October 5, 2021 Hi all, what’s the telltale signs 🪧 f burning oil? my tailpipes smoke on hard acceleration. Is that a nailed on oil burner? Is there a fix? And what do I need to look out for (e.g is it terminal)? Quote
Lynchyy Posted October 8, 2021 Author Posted October 8, 2021 Any help with this guys? Only does it on start up. Quote
Ry-B Posted October 8, 2021 Posted October 8, 2021 (edited) I'll have a crack until others who probably know more than me come along Do you check your oil regularly and if so is it going down? Do you have to top the car up a lot? This would be the easiest way to tell if you are burning oil in my opinion What colour is the smoke on hard acceleration and start up? Generally cars will use a bit of oil especially after the age and mileage most of the 350z are now Edited October 8, 2021 by Ry-B Quote
ZMANALEX Posted October 8, 2021 Posted October 8, 2021 You say in your first post that it only smokes on hard acceleration. Your second post says that it only does it on start up. Which is it? Also how many miles do you get per 1lt of oil? What is the mileage of your car? Quote
Lynchyy Posted October 8, 2021 Author Posted October 8, 2021 18 minutes ago, ZMANALEX said: You say in your first post that it only smokes on hard acceleration. Your second post says that it only does it on start up. Which is it? Also how many miles do you get per 1lt of oil? What is the mileage of your car? Sorry, some slight wording issues there. Start up revving, and noticed hard accel on a cold day (engine warm) Possibly happens on a warm day too, but cant see. Not had a chance to test the miles per litre. I service it every 3k. Its got 122,000km (or mix of Km and Miles). Quote
ZMANALEX Posted October 8, 2021 Posted October 8, 2021 You will have to carry out an accurate oil consumption test and report back if you want an informed opinion. What colour is the "smoke" Brand, and a change in oil viscosity might help as would installing a catch can. If you are getting excessive blue smoke on cold start up then that would suggest worn valve stem oil seals or worm valve guides. Excessive blue smoke on hard acceleration would suggest worn pistons, rings, or bores. Once you report back with the oil consumption numbers, further recommendations will follow. Are you running OEM cats, sport cats, or decats? Also with the ambient temperature being a bit cooler, you can expect extra exhaust emissions. Quote
Lynchyy Posted October 9, 2021 Author Posted October 9, 2021 Thanks for all of the info. I will look to do the oil check and feed back. Quote
Azurez33 Posted October 10, 2021 Posted October 10, 2021 To also build on Alex’s great info, revups do seem to burn a bit more oil than the rest but at the same time some of them don’t, with these performance cars if you do give it a hiding it will burn oil regardless anyway Do as Alex says figure out how much oil you’re burning to start with and when it burns it. When you start an engine up everything is obviously cold and it’s original size and once it heats up metal expands etc there’s always allowances for the heat expansion but to start with if somethings worn it will usually burn a lot more on the cold starts. Quote
Lynchyy Posted October 13, 2021 Author Posted October 13, 2021 Thanks guys. Im not 100% sure it was oil burning to be honest. Could just be cold weather, as the last few days when the weather has been warm, theres nothing at all out the back end. Quote
Lynchyy Posted October 13, 2021 Author Posted October 13, 2021 Im still going to monitor the oil. Will be good to know regardless. Quote
