evilscorp Posted April 9, 2019 Posted April 9, 2019 So I stupidly bought new bearings that don't have hubs for the 200sx and have removed one old one (bearing was fine, just wasting money, wont do the otherside as its a PIA). But the race is still stuck to the hub, ideally I would like to save it but it's looking unlikely, anyone got any tips? I have one of those bearing clamps but its cheap chineseium and isn't large enough to fully slide under without bending up the edges of the race. There is a slight gap that i tried to chisel but it's not for budging. Quote
Keyser Posted April 9, 2019 Posted April 9, 2019 (edited) Heat - that's what I did anyway - I have oxy acetylene though not sure a blow torch would do it - heat it then run a chisel round the lip and it should give, failing that I have cut one off with an air powered cut off tool - think big dremel but it's hard to not mark the shaft. Good luck Edited April 9, 2019 by Keyser 2 Quote
ChrisB Posted April 9, 2019 Posted April 9, 2019 Haha made me laugh.. stuff made out of cheap chinesium, ..and Keyser’s pic is so true Quote
ZMANALEX Posted April 9, 2019 Posted April 9, 2019 Knock out the ball bearing part squarely and a little bit at a time, with a large drift and a heavy hammer. The inner part which is on the sleeve, as Keyser has said, heat up quickly until red hot with a 25 oxy/acet. nozzle and it should just fall off with a little help of a thin chisel on the inner lip. Quote
