BigPoch Posted October 19, 2018 Posted October 19, 2018 Hi All, Had my car on the ramp and as you can i my arm has fallen off its bushing on the right side. Help i need is picking the right components to order: I want to replace the right side CR and on the left side just that drop links, am i correct in thinking i only need to order these parts? 1) Banana Arm - Tarmac or Moog? any advice appreciated 2) Drop links - https://www.ebay.co.uk/itm/FOR-NISSAN-350Z-Z33-3-5-2002-FRONT-LEFT-RIGHT-ANTIROLL-BAR-STABILISER-LINKS/162247440076?hash=item25c6b376cc:g:RhoAAOSwKOJYGgOt Thanks for the help Quote
MDMetal Posted October 19, 2018 Posted October 19, 2018 Just to be clear your saying you just want to replace one arm and both drop links? I'd really get both arms swapped, if one's failed the other won't be far behind. The car's going to feel a bit odd with very differently behaving arms not to mention that the process for swapping one is pretty much the same for 2 if your doing it yourself or paying it's more economical to do both at once. 1 Quote
KyleR Posted October 19, 2018 Posted October 19, 2018 It’d be cheaper to replace the bushings with poly unless the balljoint is in bad shape too. 1 Quote
mr v6 Posted October 22, 2018 Posted October 22, 2018 I replaced just that very bush 2 years ago for a fraction of the price of a cheap Chinese copy. Quote
MDMetal Posted October 22, 2018 Posted October 22, 2018 I figured the ball joints would be going as well and bought some Moog ones from Torqen and did it all myself. With the bushes you'll need to get a garage to do it so either pay for them to do everything or take the arms off and take them to the garage to press out/in. Obviously not so good if it's your only car. 1 Quote
Adrian@TORQEN Posted October 22, 2018 Posted October 22, 2018 Hi buddy, For clarity have a quick look o this thread: If you want to replace just the bushes on the banana arms, these are the ones required, always in stock: https://www.torqen.uk/nissan/350z/suspension-steering/bushes/767-350z-energy-suspension-compression-rod-bushing-kit-73121x-crb.html If you need to replace the complete arm, you have a choice between Dorman and Moog, see here: https://www.torqen.uk/53-arms-links 1 Quote
BigPoch Posted October 22, 2018 Author Posted October 22, 2018 3 hours ago, Adrian@TORQEN said: Hi buddy, For clarity have a quick look o this thread: If you want to replace just the bushes on the banana arms, these are the ones required, always in stock: https://www.torqen.uk/nissan/350z/suspension-steering/bushes/767-350z-energy-suspension-compression-rod-bushing-kit-73121x-crb.html If you need to replace the complete arm, you have a choice between Dorman and Moog, see here: https://www.torqen.uk/53-arms-links Thanks so much, exactly what i was looking for! Quote
BigPoch Posted October 22, 2018 Author Posted October 22, 2018 (edited) So do you guys i think i should first try and just replace the bushings on the banana arm? - im not sure what the balljoint condition is :S Or should i replace both the bushings and the banana arms on both sides? Thanks Edited October 22, 2018 by BigPoch Quote
BigPoch Posted October 22, 2018 Author Posted October 22, 2018 ok so sanity check: i went to see the arms again and here they are: PS: DS: Only the DS arm has dropped on the bushing. Would it be worth purchasing polyeutherane bushings and pressing them onto the existing arms first? And if the DS ball joint is gone, then i guess i have to purchase 2 new arms? (@mdmetal - as you mentioned its not a good idea to have 2 different arms on the car) Quote
MDMetal Posted October 22, 2018 Posted October 22, 2018 Personally I swapped both arms as its a driveway diy job so I did it over a weekend as at a time it was a daily car. Means it's all done and good, that's just me though! Quote
scobie140 Posted October 23, 2018 Posted October 23, 2018 Do you have any indication of when the banana arms were last changed? If only a few years old I would just change the bushes and see how you get on. Should get new poly bushes for well under £100 and you'l most likely never have to change them again. Worse case if the ball joint is knackered you can put the poly bushes into a moog/ dorman arm Quote
BigPoch Posted October 23, 2018 Author Posted October 23, 2018 4 hours ago, scobie140 said: Do you have any indication of when the banana arms were last changed? If only a few years old I would just change the bushes and see how you get on. Should get new poly bushes for well under £100 and you'l most likely never have to change them again. Worse case if the ball joint is knackered you can put the poly bushes into a moog/ dorman arm I have full service history with all invoices and reciepts and it doesnt seem they have ever been changed - i think im going to just put my mind at ease and order new arms and bushes and have it all done! Quote
Adrian@TORQEN Posted October 23, 2018 Posted October 23, 2018 20 minutes ago, BigPoch said: I have full service history with all invoices and reciepts and it doesnt seem they have ever been changed - i think im going to just put my mind at ease and order new arms and bushes and have it all done! Martin, you don't need the bushes if you're getting new arms, unless you want to use poly bushes / uprated. Arms are sufficient in your case. 1 Quote
BigPoch Posted October 23, 2018 Author Posted October 23, 2018 3 hours ago, Adrian@TORQEN said: Martin, you don't need the bushes if you're getting new arms, unless you want to use poly bushes / uprated. Arms are sufficient in your case. Thanks Adrian you have been a major help. Will be ordering two new arms from you this week ! Quote
Adrian@TORQEN Posted October 23, 2018 Posted October 23, 2018 Most welcome, Sir. Last orders will be shipped Friday before we leave for SEMA in Las Vegas. The normal shipments will resume on Monday 5th November. Quote
