bens313 Posted March 12, 2018 Posted March 12, 2018 Hello! I did a brief search and couldn't find anything on this, apologies if there is already something. I noticed the other day that my drivers side rear light cluster has about an inch of water sat in it. This was only condensation in about may last year. Is it worth taking the light unit apart, drying it out then trying to re-seal it or is it best to just buy a new cluster? Cheers! Quote
veeg33 Posted March 12, 2018 Posted March 12, 2018 If you are hand with DIY - Why not give it a try? From what I know, you'll need to bake the whole cluster in an oven or heat gun (safer option) to remove the casing. Dry out everything needed, than apply new seal + heat gun/oven to reseal the cluster. Alternatively, which model do you have? You can upgrade to the newer LED rear cluster Quote
bens313 Posted March 12, 2018 Author Posted March 12, 2018 Ah i see, so it wont be just a pop off pop on job, may as well give it a go though. I do have a 53 plate so the newer lights are tempting...... Cheers! Quote
HEADPHONES Posted March 12, 2018 Posted March 12, 2018 I found this happened to me many moons ago. With mine the cause was the dealership taking off the cluster too harshly. When you pull them out you got to resist temptation to yank one side to much which will cause them to flex and break the seal. So carefully does it Maybe mine are just unusually tight, but I got the same problem with my upgraded led clusters too! Quote
SHEZZA Posted March 12, 2018 Posted March 12, 2018 I’ve got my DE rear lights from my 55 plate zed which I’m selling once I get round to doing the Ad. if you end up needing standard replacements. Quote
bens313 Posted March 13, 2018 Author Posted March 13, 2018 Okay thanks, could you post the Ad in here when you put it up? ill have a look Quote
