Heard a rattle today, took a look underneath and found this... apperas to bit of metal something bent backwards from the front of the Zed
(The view is from just behind the driver door hinges looking toward the passenger side front wheel)
Thanks for any help,
TT
I was going to suggest the CAT heat shield but its looks plastic in the picture. If it is the heat shield its not important, its rusts away on most cars.
Here's a picture of the underside to help you.
  • Like 3
I wouldn't remove that - its part of the sub frame. . . i kid, I have no idea what i am talking about ! :D
Could be a transport block? ...
Definitely not a transport block, I'd spot that within seconds. Any more technical advice anyone PM me. :lol:
Most likely it is the silver heat shields you see under the cats at the top of the picture either side of the gearbox.
14711702281928001b.jpg?0228192833
Not sure quite what you mean - do you mean these?
Posted (edited)
Thanks for the clarification :thumbs:
Is it worth replacing them?
Up to you, they aren't really needed and are just a safety feature more than anything (if you park over dry grass / leaves it could potentially cause a fire).
PM Zmanalex / Jon@ Emperor and see if they have any for sale and make a decision based on how cheap / expensive they are.
Alternatively, you might be able to just bend it back into place and strap it together with some large jubilee clips. (Like mine :bleh:)
Edited by Strudul
Posted (edited)
Thanks for the advice.
Firstly, I'm going to see what my dealer recommends and gauge it against your response.
Personally, I'm a bit fussy about my Zed and like to keep it as near to original as I possibly can.
Thanks for taking the time to respond :thumbs:
Edited by The Trouser
