Snjur Posted January 4, 2017 Posted January 4, 2017 Looking where to source as title says Low mount steel bracket rail for bucket seats I have a set of Sparco R100 bucket seats which I want to put in use. Oem seat is to high for me. Sent from my SM-G850F using Tapatalk Quote
Tricky-Ricky Posted January 4, 2017 Posted January 4, 2017 Making a set is not hard, did that for my 350GT. Quote
Snjur Posted January 4, 2017 Author Posted January 4, 2017 Making a set is not hard, did that for my 350GT. Sure I know. I'm not at home for the moment and if I can find something for good price I would rather buy than bother my buddy to do it. Sent from my SM-G850F using Tapatalk Quote
350_Jer Posted January 4, 2017 Posted January 4, 2017 I'm getting a pair of these for my zed, side mounted so should be able to sit the seat lower, I'm in the same situation as the standard seats are too high and my head is wedged against the roof with a helmet on! http://www.ebay.co.u...=STRK:MEBIDX:IT Quote
Snjur Posted January 4, 2017 Author Posted January 4, 2017 I'm getting a pair of these for my zed, side mounted so should be able to sit the seat lower, I'm in the same situation as the standard seats are too high and my head is wedged against the roof with a helmet on! http://www.ebay.co.u...=STRK:MEBIDX:IT Thanks for info I need different type. Sent from my SM-G850F using Tapatalk Quote
Snjur Posted January 4, 2017 Author Posted January 4, 2017 I'm after this type http://www.carinteriordepot.com/product/10270567/ Sent from my SM-G850F using Tapatalk Quote
Adam B Posted January 16, 2017 Posted January 16, 2017 Run the m2 in mine. They don`t sit that low at all, removed seat cushion to get right down in the car but need to modify rail to get it proper low Quote
Snjur Posted January 17, 2017 Author Posted January 17, 2017 Anyone anywhere in UK Sent from my SM-G850F using Tapatalk Quote
350_Jer Posted January 19, 2017 Posted January 19, 2017 Run the m2 in mine. They don`t sit that low at all, removed seat cushion to get right down in the car but need to modify rail to get it proper low Does the aftermarket seat still sit lower with the m2 subframes than the standard seat? Quote
RobPhoboS Posted January 31, 2017 Posted January 31, 2017 (edited) Any more luck on finding something Snjur ? The only other thing I can think of is doing what a friend does in his Superleggera for track days, just remove the arse cushion and you instantly gain more headroom. IF that's what you require. I am going to pull out my drivers seat this weekend to see what's what underneath, as I'd like to have it mounted lower by about 1cm-2cm hah. Edited January 31, 2017 by RobPhoboS Quote
Snjur Posted January 31, 2017 Author Posted January 31, 2017 Any more luck on finding something Snjur ?The only other thing I can think of is doing what a friend does in his Superleggera for track days, just remove the arse cushion and you instantly gain more headroom. IF that's what you require. I am going to pull out my drivers seat this weekend to see what's what underneath, as I'd like to have it mounted lower by about 1cm-2cm hah. No I will fabricate my own. The cheapest option I managed to find was 280/290 for pair Buddy has them on his Z-a. I will take one like sample and give it to a friend who works in metal shop. Depending from material and thickness used he told me it shouldn't be more than 150 euro for pair. Which is a fair deal Sent from my SM-G850F using Tapatalk 1 Quote
Snjur Posted January 31, 2017 Author Posted January 31, 2017 Any more luck on finding something Snjur ?The only other thing I can think of is doing what a friend does in his Superleggera for track days, just remove the arse cushion and you instantly gain more headroom. IF that's what you require. I am going to pull out my drivers seat this weekend to see what's what underneath, as I'd like to have it mounted lower by about 1cm-2cm hah. No I will fabricate my own. The cheapest option I managed to find was 280/290 for pair Buddy has them on his Z-a. I will take one like sample and give it to a friend who works in metal shop. Depending from material and thickness used he told me it shouldn't be more than 150 euro for pair. Which is a fair deal Sent from my SM-G850F using Tapatalk Quote
